Programming
Hi! We're two girls who need HELP!!
We are trying to program an automatic chees slider.
If a button is pressed, a led should turn on and a motor is starting.
We also going to use an IR-sensor wyc h2010.
This is what we've done so far. Please help us!
int motorPin = 13;
const int buttonPin = 2;
const int ledPin = 13;
int buttonState = 0;
pinMode(motorPin, OUTPUT);
digitalWrite(motorPin, 0);
pinMode(ledPin, OUTPUT);
pinMode(buttonPin, INPUT);
buttonState = digitalRead(buttonPin);
if (buttonState==HIGH){
digitalWrite(ledPin, HIGH);
digitalWrite(motorPin, HIGH);
delay(2000);
digitalWrite(ledPin, LOW);
What does that code ACTUALLY do? How does that differ from what you want? How is the switch wired?
Nothing happend when I push the button :frowning:
Do you really plan to use the same pin for motor and led?
Three questions, one answer is the wrong ratio.
try this :
int motorpin = 12;//dont use 13
int buttonpin = 2;
int ledpin = 13;
 pinMode(motorpin, OUTPUT);
 pinMode(buttonpin, INPUT);
 pinMode(ledpin, OUTPUT);
 if(digitalRead(buttonpin) == HIGH) {
   digitalWrite(ledpin, HIGH);
   digitalWrite(motorpin, HIGH);
   delay(2000);
   digitalWrite(ledpin, LOW);
   digitalWrite(motorpin, LOW);
WOOW IT WORKS! Thank you so much!!! You're the best!
Thank you :slight_smile:
