Programming
I am trying to build an object avoidance car for my project in class. The car has the HC-SR04 mounted on a SG90. This portion works. I also have the L298N as the h-bridge and it works. Where i am having trouble is the compare statement in the programming. Any advice would be greatly appreciated.
#include<Servo.h>
Servo myservo;
const int Dir1PinA = 6; // direction motor A
const int Dir2PinA = 7; // direction motor A
const int Dir1PinB = 9; // direction motor B
const int Dir2PinB = 10; // direction motor B
const int speedPinA = 5; // pwm motor A
const int speedPinB = 11; // pwm motor B
int pos = 0;
int photocellPin = A0;// Photocell connected to analog pin 0
int photocellVal = 0; // define photocell variable
int ledPin = 13;// LED connected to digital pin 9
int ledState = 0;//state of the led
int fadeDown = 30;//delay per fade
int fadeUp = 20;//delay per fade
int minLight = 700;//min light threshold
int maxLight = 700;//max light threshold
int leftDistance, rightDistance, fwdDistance;
const int trigPin = 2;
const int echoPin = 3;
long duration, inches, in, cm;
int yes, no;
pinMode(photocellPin, INPUT);
pinMode(ledPin, OUTPUT);
myservo.attach(12);
myservo.write(100);
delay(1500);
photocellVal = analogRead(photocellPin);
if (photocellVal < minLight and ledState == 0) {
fadeLed(1);
else if (photocellVal > maxLight and ledState == 1){
fadeLed(0);
leftPing();
fwdPing();
rightPing();
compareDistance();
long microsecondsToInches(long microseconds)
return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
return microseconds / 29 / 2;
void fadeLed (int num) {
if (num == 1) {
for (int fadeValue = 0 ; fadeValue <= 255; fadeValue += 5) {
analogWrite(ledPin, fadeValue);
delay(fadeUp);
ledState = 1;
else {
for (int fadeValue = 255 ; fadeValue >= 0; fadeValue -= 5) {
delay(fadeDown);
ledState = 0;
void compareDistance()
if (leftDistance = no, fwdDistance = yes, rightDistance = yes) {
turnleft();
delay(800);
else if (leftDistance = yes, fwdDistance = yes, rightDistance = no) {
turnright();
delay(800);
else if (leftDistance = no, fwdDistance = no, rightDistance = no) {
forward();
delay(1500);
else if ( leftDistance = yes, fwdDistance = yes, rightDistance = yes) {
reverse();
delay(800);
void leftPing()
for (pos = 100; pos >= 50; pos -= 1) {
myservo.write(pos);
delay(15);
delay(600);
getDistance();
if(inches>10)
leftDistance = no;
else(inches<10);
leftDistance = yes;
void fwdPing(){
for (pos = 50; pos < 100; pos += 1)
{ // in steps of 1 degree
myservo.write(pos);
delay(15);
delay(600);
getDistance();
if(inches>10)
fwdDistance = no;
else(inches<10);
fwdDistance = yes;
void rightPing(){
for (pos = 100; pos < 150; pos += 1)
myservo.write(pos);
delay(15);
delay(600);
getDistance();
if(inches>10){
rightDistance = no;
else(inches<10);
rightDistance = yes;}
for (pos = 150; pos >= 100; pos -= 1)
myservo.write(pos);
delay(15);
void getDistance()
pinMode(trigPin, OUTPUT);
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
pinMode(echoPin, INPUT);
duration = pulseIn(echoPin, HIGH);
inches = microsecondsToInches(duration);
cm = microsecondsToCentimeters(duration);
Serial.print(inches);
Serial.print("in, ");
Serial.print(cm);
Serial.print("cm");
delay(100);
void turnleft()
digitalWrite(Dir1PinA, LOW);
digitalWrite(Dir2PinA, HIGH);
digitalWrite(Dir1PinB, LOW);
digitalWrite(Dir2PinB, HIGH);
analogWrite(speedPinA, 130);
analogWrite(speedPinB, 130);
void turnright()
digitalWrite(Dir1PinA, HIGH);
digitalWrite(Dir2PinA, LOW);
void forward()
analogWrite(speedPinA, 70);
analogWrite(speedPinB, 70);
void reverse()
digitalWrite(Dir1PinB, HIGH);
digitalWrite(Dir2PinB, LOW);
void stop()
analogWrite(speedPinA, 0);
analogWrite(speedPinB, 0);
(deleted)
What?
Please, please, use code tags when posting code.
Why is this simple thing so hard to understand?
if(inches>10)
  fwdDistance = no;
else(inches<10);
  fwdDistance = yes;
The else part does not need a condition. And also not a semicolon as that excludes the next part between the curlies from being part of the else
if(inches>10)
  fwdDistance = no;
  fwdDistance = yes;
PS please use code tags in future. If you quote this post you cn see how it's done.
Yes, perhaps learning C would be a start.
'yes' and 'no' are uninitialized int variables, the ',' operator is very obscure and clearly not what is
wanted, and '=' is not a comparison at all, its an assignment.
Why are calling integers 'yes' and 'no'? Perhaps you should be using boolean?
sterretje:
if(inches>10)
 fwdDistance = no;
else(inches<10);
 fwdDistance = yes;
Unless you really do want to ignore the case where they're equal.
What i want the program to do is to Ping for distance at 3 points. left, forward and right. then determine if the way is clear. if the ping distance is grater then 10 inches then there is no obstacle. After that i want it to compare the distances to determine where the obstacle is. this will determine the direction to go. this program pings fine but dose not execute the direction. Thank you for your help.
spycatcher2k:
and? why not &
  1. Because & is a bitwise and. It is not the same as "&&".
  2. Because "and" is more readable than "&&".
