Please help fix the code for when keep button press output is only one time high and low
Thanku
kuni122000:
Thanku
No need to double post!
Would you like us to wave a magic wand?
Paul
Welcome to the group.
Perhaps you ment to attach your current sketch for us to take a look at.
What is your experience in programming and electronics.
Always show us your ‘current’ compete sketch.
Use CTRL T to format the sketch.
Please use code tags.
Use the </> icon in the posting menu.
[code] Paste sketch here. [/code]
Show us a good schematic of your circuit.
Show us a good image of your wiring.
/* switch
- Each time the input pin goes from LOW to HIGH (e.g. because of a push-button
- press), the output pin is toggled from LOW to HIGH or HIGH to LOW. There's
- a minimum delay between toggles to debounce the circuit (i.e. to ignore
- noise).
- David A. Mellis
- 21 November 2006
int inPin = 2; // the number of the input pin
int outPin = 13; // the number of the output pin
int state = HIGH; // the current state of the output pin
int reading; // the current reading from the input pin
int previous = LOW; // the previous reading from the input pin
// the follow variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long time = 0; // the last time the output pin was toggled
long debounce = 200; // the debounce time, increase if the output flickers
pinMode(inPin, INPUT);
pinMode(outPin, OUTPUT);
reading = digitalRead(inPin);
// if the input just went from LOW and HIGH and we've waited long enough
// to ignore any noise on the circuit, toggle the output pin and remember
// the time
if (reading == HIGH && previous == LOW && millis() - time > debounce) {
if (state == HIGH)
state = LOW;
state = HIGH;
time = millis();
digitalWrite(outPin, state);
previous = reading;
Change:
long time = 0;
to:
unsigned long time = 0;
You may have to change this:
to:
pinMode(inPin, INPUT_PULLUP);
How is your switch wired?
Move this:
previous = reading;
into:
the 1st 'if' block.
What are you trying to do with this project?
Hello
I am trying to make simple door bell
Because when some body keep press door bell switch
I want hear sound only one time
Thanku
How will you be connecting the switch?
How far away from the Arduino will it be?
larryd:
Not design yet and still trying fix the code
Thanku
@kuni122000
Add a comment to each line of this code.
Attached your commented code to this thread so we can review it.
/* switch
noise).
David A. Mellis
21 November 2006
#define PUSHED HIGH
const byte outPin = 13; //
const byte inPin = 2; // <----<<<< Connect 4.7K resistor form D02 to GND.
// Connect one contact of the switch to D02, other contact to +5V
// int state = LOW; //
int reading; //
int previous; //
unsigned long timeMillis; //
unsigned long onMillis; //
const unsigned long debounce = 200; //
const unsigned long duration = 1000; //
previous = digitalRead(inPin);
digitalWrite(outPin, LOW);
if (previous != reading && millis() - timeMillis > debounce)
timeMillis = millis();
previous = reading;
if (reading == PUSHED)
digitalWrite(outPin, HIGH);
onMillis = millis();
if (digitalRead(outPin) == HIGH && millis() - onMillis >= duration)
}// END of loop()
Edit:
Update sketch
Use the S1 example see in this schematic:
Click on the image for full resolution.
Thanks lot your response
i follow it
Thanku
@kuni122000
Just a minute, you have some homework.
Comment every line of code in the sketch then post a copy of it here so we can see your work.
larryd:
@kuni122000
Just a minute, you have some homework.Comment every line of code in the sketch then post a copy of it here so we can see your work.
/* switch
noise).
David A. Mellis
21 November 2006
#define PUSHED HIGH
const byte outPin = 13;//
const byte inPin = 2;// <----<<<< Connect 4.7K resistor form D02 to GND.
//Connect one contact of the switch to D02, other contact to +5V
int state = LOW;//
int reading;//
int previous;//
unsigned long timeMillis;//
unsigned long onMillis;//
const unsigned long debounce = 100; //
const unsigned long duration = 500; //
previous = reading;
// END of loop()
Guess there is a translation issue.
larryd:
/* switch
noise).
David A. Mellis
21 November 2006
#define PUSHED HIGH
const byte outPin = 13;// for bell
int state = LOW;//the current state of the output pin
int reading;//the current state of the button pin
int previous;//the previous state of the button pin
const unsigned long debounce = 200; //the last time the output pin was toggled
const unsigned long duration = 500; //the debounce time; increase if the output flickers
previous = reading;
digitalWrite(outPin, HIGH);//ding
digitalWrite(outPin, LOW);//dong
}else{
if (digitalRead(outPin) == LOW && millis() - timeMillis <= duration)
digitalWrite(outPin,HIGH);//another ding when switch release
digitalWrite(outPin,LOW);//another dong when switch release
}// END of loop()
Please describe what YOU think this line of code is doing:
Paul
