Programming
Hi.
Dose this addition have how to programming in it I am 69 year old and new at this i was not sure
which addition to download or where to go for the right download.
Regards Roger
  1. Download the code here to start (Windows)
    https://www.arduino.cc/download_handler.php
    Save the .zip file, unzip it, and run arduino.exe when it finishes
I have it in the folder c:\arduino 1.8.5\
  1. Run the examples under File: Examples: 01.Basics and start learning the basics.
Most code can be set up like this:
(Use the </> button to get a code box like this in the forum)
// this is a comment line
// declare any variables,
unsigned int analogValue; // a value from 0 to 65535
// assign names to pins.
byte  buttonPin = 2; // a switch connected  between pin 2 and Gnd
// then have a setup section that runs once
void setup(){
pinMode (buttonPin, INPUT_PULLUP); // turn on the internal pullup resistor
Serial.begin(9600); // turn on the serial interface so display stuff on the serial monitor
} // end of setup section
// then have a section that runs over and over until you press reset
void loop(){
  if (digitalRead(buttonPin) == LOW){ // was the button connecting the pin to Gnd pressed?
    analogValue = analogRead(A0); // read the voltage on pin A0, result will be 0 to 1023
    Serial.print ("A0 = "); // print a label
    Serial.println (analogValue); // and the value read
    delay(500); // waitn 500 mS, 1/2 second, so you don't have a flood of data coming out
  } // end of button reading
} // end of loop
Pressing CTRL-T, or Tools:Autoformat, will make the code more readable, and help you find mis-matched ( ) pairs or { } pairs.
Press the check-mark button, that will save your code and Compile the code and let you find any errors.
Press the right-arrow button to upload the code into your board.
How’s that for a start?
You can also select Help: and open/read topics there.
I believe rogerbrowne is asking about the Arduino Web Editor, since this is that forum section. However, I do prefer the standard IDE (which CrossRoads's instructions apply to).
There are some cases where the Arduino Web Editor is a good choice though. You can find a guide to getting started with the Arduino Web Editor here:
Ah, didn't scroll far up enough to notice the forum section.
