Hi, I made some little changes to the number 3 project, Love O Meter.
I thought it would be nice to have the possibility to set the room temperature directly from the device instead that manually set the temperature in the code.
I used a push button, and a yellow led; when the pin connected to the switch is high, the program turns off the red led in the case they are still on, turn on a yellow led that indicates the device is storing a new value for the baselineTemp variable, counts for about 25 seconds which is the time needed to cool down the temp sensor and finally the sensor actually read and store the new value for baselineTemp.
The piece of code I added to the original one is between the **** marks, then I changed the constant baselineTemp in a global variable, added the yellow pin(6) in void setup and added 1.9 degrees as threshold temperature for the first red led to turn on.
In this way, it is possible to continue using the sensor and set new room temperature values without interrupting the program. Please let me know if I could do it differently with fewer lines of code. Your feedback is very important to me.
const int sensorPin = A0;
float baselineTemp = 21.5;//room temperature initial value
int switchState = 0;
Serial.begin(9600); // open a serial port
for(int pinNumber = 2; pinNumber<6; pinNumber++){
pinMode(pinNumber,OUTPUT);
digitalWrite(pinNumber, LOW);
pinMode(6, INPUT);
switchState = digitalRead(6);
//when switch is pressed set a new value for baselineTemp
if (switchState == HIGH){
for(int x=0; x<5; x++){//turn off the red leds
digitalWrite(x, LOW);
digitalWrite(5, HIGH);//turn on a yellow led
delay(pow(12.5,4));//time needed to 'cool down' the sensor ~25 sec
baselineTemp = (((analogRead(sensorPin)/1024.0*5.0)-.5)*100);//convert sensor voltage in temp and store the new value
digitalWrite(5, LOW);
int sensorVal = analogRead(sensorPin);
Serial.print("Room Temp: ");
Serial.print(baselineTemp);
Serial.print(", Sensor Value: ");
Serial.print(sensorVal);
//convert the ADC reading to voltage
float voltage = (sensorVal/1024.0)* 5.0;
Serial.print(", Volts: ");
Serial.print(voltage);
Serial.print(", degrees C: ");
//convert the voltage to temperature in degrees
float temperature = (voltage -.5)*100;
Serial.println(temperature);
if(temperature < baselineTemp+1.99){
digitalWrite(2, LOW);
digitalWrite(3, LOW);
digitalWrite(4, LOW);
}else if(temperature >= baselineTemp+2 && temperature < baselineTemp+4){
digitalWrite(2, HIGH);
}else if(temperature >= baselineTemp+4 && temperature < baselineTemp+6){
digitalWrite(3, HIGH);
}else if(temperature >= baselineTemp+6){
digitalWrite(4, HIGH);
delay(5);
This is the schematic. I used 560-ohm resistors for the led instead of the 220.
