Project 07 Serial.println error message
Hey everyone, I am trying to access the Serial Monitor so that I can find out the different voltages that signalise different frequencies. Here is the code (copied from Projects book):
int notes = {262,294,330,349};
int keyVal = analogRead(A0);
Serial.println = (keyVal)
However, if I try to upload the arduino Uno (in order to access Serial Monitor), I get the error Message:
invalid use of member function 'size_t Print::println()' (did you forget the '()' ?)
Does anyone know what this means?
Thanks in advance, Daniel :slight_smile:
Serial.println = (keyVal) You didn’t copy that, I hope
Have another look at the original code, character-by-character
Ohhhh, sorry for wasting your time, the book says Serial.println(keyVal)
wow, I checked it like 5 times but now I finally noticed... That's true = would not make any sense.
Thank you anyway!
Daniel
Not a waste of time at all.
The compiler rarely makes a mistake, so if it points out a problem, it’s most likely your problem.
It’s an unfortunate truth that a lot of programming is often a big game of spot-the-difference.
Ok, Thank you!
