Hello all,
I'm working my way through the Arduino Starter Kit. I find myself in the same situation, on project 10, as Pando in this post. I've wired everything up and transcribed the code from the manual, but nothing happens. Zip. ![]()
It turns out Pando's problem was a borked H-bridge. I'm wondering if I'm in the same situation. Here is what I have done to debug the situation so far.
First, I opened a serial connection in the code and printed out the value of all variables before and after all tests and assignment statements (with delay()'s after each Serial.print so I could read it all). This showed me that the switches and the potentiometer were affecting the value of the variables as expected.
Second, I wired gpio pin 9 to an LED instead of pin 1 of the H-bridge. In the above mentioned post, kaning found that he wasn't getting signals from his output pin (he doesn't say why nor how he fixed it). I wanted to test for that. The LED lit up as expected in reponse to switch presses. So I think I can conclude that the signal was also getting as far as the H-bridge.
Similarly, I tested the signal coming from gpio output pins 2 and 3 by connecting them to a couple of LEDs instead of pins 2 and 7 of the H-bridge. Like above, the LEDs responded as expected to the direction switch being closed.
Oh yeah, and before all this, I also wired the motor directly to 9v just to make sure that the motor was working. It is.
Have I covered it? Is there anything else people would recommend I check before assuming that my H-bridge is faulty?
Thanks
