Hi,i’ve some weird charaters in the lcd,how can i fix it?(check image)thanks
It is a little difficult to see in the photo, but it looks to me that you have pin 1 of the LCD display (Vss) connected to 5v on the breadboard, when it should be connected to ground, and pin 2 of the LCD (Vcc) should be connected to 5v on the breadboard.
Also make sure you have the breadboard ground connected to the arduino board ground pin, and everything grounded properly, otherwise the arduino will send all kinds of crazy data, that will just be gibberish.
Please post to let me know if this fixed the problem.
If not please post a photo showing all connections both on the breadboard and the arduino and a copy of the code.
Now I dont have enough light to take a picture,tomorrow morning i'll do it.Thanks
#include <LiquidCrystal.h>
LiquidCrystal lcd(12,11,5,4,3,2);
const int switchPin=6;
int switchState=0;
int prevSwitchState=0;
int reply;
lcd.begin(16,2);
pinMode(switchPin,INPUT);
lcd.print("Ask the");
lcd.setCursor(0,1);
lcd.print("Crystal Ball!");
switchState=digitalRead(switchPin);
if (switchState!=prevSwitchState){
if(switchState==LOW){
reply=random(8);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("The Ball says: ");
lcd.setCursor(0,1);
switch(reply){
case 0:
lcd.print("Yes");
case 1:
lcd.print("Most likely");
case 2:
lcd.print("Certainly");
case 3:
lcd.print("Outlook good");
case 4:
lcd.print("Unsure");
case 5:
lcd.print("Ask again");
case 6:
lcd.print("Doubtful");
case 7:
lcd.print("No");
prevSwitchState=switchState;
picture of the issue?
Thx
were you able to figure out what the problem was?
wth is my problem?!?!?
the error says:
exit status 1
‘prevSwitchState’ was not declared in this scope
and my script is:
LiquidCrystal lcd(12, 11, 5, 4, 3, 2)
; const int switchPin = 6;
int switchState = 0;
int prewSwitchState = 0;
int reply;
lcd.setCursor(0, 1);
pinMode(switchPin, INPUT);
lcd.print(“Ask the”);
lcd.print(“Crystal Ball!”);
switchState = digitalRead(switchPin);
if (switchState != prevSwitchState) {
if (switchState == LOW) {
reply = random(8 //ignore this empty space);
lcd.clear();
lcd.setCursor(0, 0);
lcd.print(“The bal says:”);
switch (reply) {
case 0;
lcd.print(“Yes”);
case 1;
lcd.print(“Most likely”)
case 2;
lcd.print(“Certainly”)
case 3;
lcd.print(“Maybe…”)
case 4;
lcd.print(“Unsure”)
case 5;
lcd.print(“Ask again”);
case 6;
lcd.print(“Doubtful”);
case 7;
lcd.print(“Nope.”);
prevSwitchState = switchState;
I dont understand what is the problem pls anyone help me
Thanks
