Project 11 Upgrading with a hack?
Hi I want to improve on project 11 by making it return random answers to each line, not just the bottom line, but I'm not getting the result I want.
So far I've only be able to get both lines to return random answers that are seemingly permanently paired. Can anyone help me find an answer to this?
For example, the answers are always return like this:
Case 1
Case 1
or
Case 3
Case 3
What I want to achieve is:
Case 1
Case 5
or
Case 7
Case 3
The original code:
switchState = digitalRead(switchPin);
if (switchState != prevSwitchState) {
if (switchState == LOW) {
reply = random( 8 );
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("the ball says:");
lcd.setCursor(0, 1);
switch (reply) {
case 0:
lcd.print("Yes");
case 1:
lcd.print("Most likely");
...continues...
case 7:
lcd.print("No");
prevSwitchState = switchState;
And the changes I made:
lcd.clear();
switch(reply){
case 0:
lcd.print("Yes");
case 1:
...continues...
case 7:
lcd.print("No");
switch(reply){
case 0:
lcd.print("Yes");
case 1:
...continues...
case 7:
lcd.print("No");
Your variable reply = random( 8 ); will be assigned to example 1 and then your LCD will output the same answer for both rows on the LCD. To have two different random answers, try to initiate another random variable lets say reply2 = random( 8 ); and then assign that for row 2's switch cases.
