Hi all,
I am still learning by reading the book "Beginning Arduino" by Michael Mc Roberts..Project 20 uses an 8x8 LED matrix and two 74HC595 shift registers..My LED matrix was not the same as the authors original sketch so I modified the sketch to make it work..It is supposed to be a rolling wheel that scrolls from left to right across the matrix..No Problem that works as intended..I then decided to see If I could replace the wheel with my initials..The code for the two dimensional array was modified so as to display my initials(jp)..That worked perfectly also.. Now that all is working, I wonder if I can scroll instead of left to right, scroll right to left..I tried various things but evidently yet do not have enough understanding how to do that..It would seem an easy task but
more than I can apparently figure out..
Can someone look at this code and point if and how this can be done?..
I thank you all for reading this and I appreciate any pointers you can offer..
Jolphil
/ Project 20
#include <TimerOne.h>
int latchPin = 8; //Pin connected to Pin 12 of 74HC595 (Latch)
int clockPin = 12; //Pin connected to Pin 11 of 74HC595 (Clock)
int dataPin = 11; //Pin connected to Pin 14 of 74HC595 (Data)
byte frame = 0; // variable to store the current frame being displayed
byte led[8][8] = { {0, 120, 72, 120, 8, 10, 14, 0}, // 8 frames of an animation
{0, 120, 72, 120, 8, 10, 14, 0} };
pinMode(latchPin, OUTPUT); // set the 3 digital pins to outputs
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
Timer1.initialize(10000); // set a timer of length 10000 microseconds
Timer1.attachInterrupt(screenUpdate); // attach the screenUpdate function
for (int i=0; i<8; i++) { // loop through all 8 frames of the animation
for (int j=0; j<8; j++) { // loop through the 8 rows per frame
led[i][j]= led[i][j] << 1 | led[i][j] >> 7; // bitwise rotation
frame++; // go to the next frame in the animation
if (frame>7) { frame =0;} // make sure we go back to frame 0 once past 7
delay(250); // wait a bit between frames
void screenUpdate() { // function to display image
byte row = B10000000; // row 1
for (byte k = 0; k < 9; k++) {
digitalWrite(latchPin, LOW); // open latch ready to receive data
shiftIt(~led[frame][k] ); // LED array (inverted)
shiftIt(row); // row binary number
// Close the latch, sending the data in the registers out to the matrix
digitalWrite(latchPin, HIGH);
row = row >> 1; // bitshift right
void shiftIt(byte dataOut) {
// Shift out 8 bits LSB first, on rising edge of clock
boolean pinState;
//clear shift register read for sending data
digitalWrite(dataPin, LOW);
// for each bit in dataOut send out a bit
//set clockPin to LOW prior to sending bit
digitalWrite(clockPin, LOW);
// if the value of DataOut and (logical AND) a bitmask
// are true, set pinState to 1 (LOW)
if ( dataOut & (1<<i) ) {
pinState = LOW;
else {
pinState = HIGH;
//sets dataPin to HIGH or LOW depending on pinState
digitalWrite(dataPin, pinState);
//send bit out on rising edge of clock
digitalWrite(clockPin, HIGH);
digitalWrite(clockPin, LOW); //stop shifting
