what do i need to do to get this program to work the error is ‘potVal’ was not declared in this scope
and i need help on how to fix it if anyone could help that would be great
#include <Servo.h>;
Servo myServo;
int const potPin = A0;
int potVal;
int angle;
myServo.attach(9);
potVal = analogRead(potPin);
Serial.print(“potVal: “);
Serial.print potVal ;
angle = map(potVal, 0, 1023, 0, 179);
Serial.print(”, angle:”);
Serial.println(angle)
myServo.write(angle);
delay(15);
Please follow the advice on posting a programming question given in Read this before posting a programming question
In particular note the advice to Auto format code in the IDE and to use code tags when posting code here
Have another closer look at the code in the book
#include <Servo.h>;
Servo myServo;
int potVal;
int angle;
Should these statements be inside setup() ?
I think not otherwise the variables will not be available outside of setup()
As well as what @UKHeliBob has pointed out.
Should be;
Serial.print (potVal) ;
Tom...
Hello beenobread,
You might find this useful Variable scope as your problem is caused by not understanding variable scope.
I found that whole of that web site useful when I was learning C.
Please use code tags </> when posting code.
Recheck the code in the book. The code you have posted here has many errors...
You can find the programs in the IDE:
File > Examples > 10.StarterKit_BasicKit
