Hi, I'm doing a school project about the communication between two arduino uno, and I'm kinda stucked, I don't really understand what I'm doing wrong and even asking around(Discord etc.) isn't working.
The goal of the project is to be able to transmit messages (the letters, in my case, s, u and p in ascii) to the other arduino, and to light up, in bot arduinos, the espective leds(the red one for the s, orange one for the u, the yellow one for the p and the last one is an "error", the green led should not be in the first arduino, since the goal of the error is to press the button and make the led light up only in the second arduino, but I needed it to test it), but it doesn't work ..
We're yet to study the serial and i'm really having a lot of trouble with this project
Since I'm italian I tried to translate the comments, I'm really sorry if the translation and my english are bad
This is the trasmitter code:
//led statement
int ledRosso=12;
int ledArancio=11;
int ledGiallo=10;
int ledErrore=9;
//statement buttons with the respective colors of the LEDs
int botRosso=8;
int botArancio=7;
int botGiallo=6;
int botErrore=5;
//transmitter declaration
int TX=4;
//bit time declaration
int tbit=1;
//counter declaration for the for loop
int i=0;
//declaration of the frame to be transmitted (= SUP)
//frame: start bit, 8 bit (letter in ascii), parity bit, stop bit
//start / stop bit = 1
//parity coding = even
//plot of the letter 'S' in ascii = 01010011
int S[11]= {1,0,1,0,1,0,0,1,1,0,1};
//plot of letter 'U' in ascii = 01010101
int U[11]= {1,0,1,0,1,0,1,0,1,0,1};
//plot of the letter 'P' in ascii = 01010000
int P[11]= {1,0,1,0,1,0,0,0,0,0,1};
//plot of letter 'U' with ascii error = 01111101
int Ue[11]= {1,0,1,1,1,1,1,0,1,0,1};
//led setup
pinMode(ledRosso, OUTPUT);
pinMode(ledArancio, OUTPUT);
pinMode(ledGiallo, OUTPUT);
pinMode(ledErrore, OUTPUT);
//button setup with internal resistance
pinMode(botRosso, INPUT_PULLUP);
pinMode(botArancio, INPUT_PULLUP);
pinMode(botGiallo, INPUT_PULLUP);
pinMode(botErrore, INPUT_PULLUP);
//transmission setup
pinMode(TX, OUTPUT);
//control of the red button to switch on the respective LED
if(digitalRead(botRosso)==LOW){
//switching on of the red led
digitalWrite(ledRosso, HIGH);
//transmission of the plot of the letter S in ascii = 10101001101
//start bit, ascii letter, parity bit and stop bit
for(i=0; i<11; i++){
digitalWrite(TX, S[i]);
delay(tbit);
//control of the orange button to switch on the respective LED
else if(digitalRead(botArancio)==LOW){
//the orange led lights up
digitalWrite(ledArancio, HIGH);
//transmission of the plot of the letter U in ascii = 10101010101
digitalWrite(TX, U[i]);
delay(tbit);
//control of the yellow button to switch on the respective LED
else if(digitalRead(botGiallo)==LOW){
//switching on of the yellow led
digitalWrite(ledGiallo, HIGH);
//transmission of the plot of the letter P in ascii = 10101000001
digitalWrite(TX, P[i]);
delay(tbit);
//control of the green button to switch on the respective LED
else if(digitalRead(botErrore)==LOW){
//green led lights up
digitalWrite(ledErrore, HIGH);
//plot transmission of letter U in modified ascii = 10111110101
digitalWrite(TX, Ue[i]);
delay(tbit);
else{
digitalWrite(ledRosso, LOW);
digitalWrite(ledArancio, LOW);
digitalWrite(ledGiallo, LOW);
digitalWrite(ledErrore, LOW);
digitalWrite(TX, LOW);
delay(15*tbit);
This is the reciver code:
//led statement
int ledRosso=7;
int ledArancio=6;
int ledGiallo=5;
int ledErrore=4;
//declaration reception
int RX=10;
int tbit=1;
//declaration of half the bit time
float mtbit=tbit/2;
//declaration with the for loop with which it will read the incoming message
int i=0;
//declaration of the supporting variable reading the message arriving from the transmission
int messaggio[10];
//led setup
//reciver setup
pinMode(RX, INPUT);
while(digitalRead(RX)==HIGH){};
delayMicroseconds(mtbit);
if(digitalRead(RX)==HIGH){
for(i=0; i<10; i++){
messaggio[i]=digitalRead(RX);
delay(tbit);
//check of the message received to switch on the red LED if(messaggio[0]==1&&messaggio[1]==0&&messaggio[2]==1&&messaggio[3]==0&&messaggio[4]==1&&messaggio[5]==0&&messaggio[6]==0&&messaggio[7]==1&&messaggio[8]==1&&messaggio[9]==0&&messaggio[10]==1){
In the reciver I just tried to light up a led(the red one) but it doesn't work
I'm really sorry for copying the code here but .txt aren't fine
I thank in advance who will help me, this is the first time I write in a forum for help so sorry if I made a mistake in selecting the section or something else
