project advise..
Greeting to all. This is my first project build of any kind.
Before I go into the details of purpose of the build I have some basic question about the:
Nano V3.0 for Arduino & 8X Seven Segments Display + 8X Key + 8X Double Color LED Module for Arduino.
  1. How should I connect the 2 units named aboved on the PCB.
  2. Should I load the OS before or after the 2 units are connected.
I have other questions but these two are most immediate. I got the idea for this build from another more advanced builder but up till now I cannot get a reply from them.
I feel after I have got the material merged together I can work out the rest with minimal help.
Thanks in advance.
1) Need the specs on that board, because it has additional electronics on the back - probably a MAX7219/21, and a 16 bits of shift register for the 8 2-color LEDs - does the seller have any specs or information on it? How are the buttons wired? etc - there is nowhere near enough information here.
2) Arduino does not have an OS. If you mean the bootloader, then yes - but if that's an official board (and probably even if it's not) the bootloader is pre-installed.
This one ? http://www.dx.com/p/8x-digital-tube-8x-key-8x-double-color-led-module-81873 It is used with this code : https://code.google.com/p/tm1638-library/ Also how to connect can be found at the tm-1638-library project.
Full documentation : http://csserver.evansville.edu/~mr63/Courses/Projects/TM1638en.pdf
Thank you both again. I'm trying to read as fast as I can. @ Drazzy http://www.dealextreme.com/p/arduino-nano-v3-0-81877 also which board are you asking specs for? @Peter_n I've read the tm1638 pdf. I see the diagrams but I dont see where I should or could add wiring.
Thank you.
Maybe I should add the question is there a specific PCB that I should use to connect the 2 units together?
After re reading the offered pdf I find that section 11 is the closest diagram for what I am looking for. Am I right?
Hi, Can you tell us what experience you have with electronics, programming and hardware?
Thanks Tom..... :)
Experience is low. I can use and read a voltmeter. I can solder. I have read alot of electrical theory books. Its the practical that I lack in. I am in the midst of learning C++. I am A+ & N+ certified if you are talking about pc hardware.
I see after further reading I am missing a number of important devices for connecting this nano to PCB.
ex. https://www.youtube.com/watch?v=4QD80OtV3MI
I thought this would be a simple and quick wire up. Well I learned to swim once. I'm here to learn to swim again.
So I see how the Nano is attached but I still need help with how to attach the display board.
Thank you all. This will not be my last project, its just that if I dont start with one (a project) when will I ever start one?
Heres another example of how the nano is connected to the PCB. This time its directly embedded to the board.
How is a wireless doorbell related to the OP’s post ?
