At his point you have more then a few problems. This sounds like a school project where some how you missed the information you needed, my answer reflects that. In order to pick the amplifier you need to read the motor specifications and amplifier specifications then get an amplifier that will supply them to the motor. It would much more cost effective to purchase an arbitrary function generator then create the signals you are talking about in a pure enough form so you can get valid results. ballscrewbob has given you an assignment, as have I so we can help you. This response is to help you get started in solving your problem, not solve it for you.
Good Luck & Have Fun!
Gil
thanks for the replys. I have change some things in my project. im using arduino due DAC output now to generate the signals i want. Next i want to build an analog H bridge but dont know nothing about it. How to even start with this, witch parts to use. I will be very grateful for any help.
