Project Assistance (DHT11 and Grove stuff)
I'm a kid working on a grove project, which involves a DHT11 humidity and temp. sensor. I'm currently using the grove beginner kit, and trying to connect it with an arduino uno as well. My problem is that i cant connect it with the UNO and i dont know how to build off of my current code to add other items, like a mist creator. This is my current code. Can anyone help me? (This is project due 3 days later so please help)
#include <DHT11.h>
#include <Grove_Temperature_And_Humidity_Sensor.h>
#include <dht11.h>
#define DHT11PIN 4
dht11 DHT11;
void  setup()
  int chk = DHT11.read(DHT11PIN);
  Serial.print("Temperature  (C): ");
  Serial.println((float)DHT11.temperature, 2);
  delay(2000);
if (Serial.println=("37")) {
(empty part where i intend to add the mist)
I also get this error message and don't know how to deal with it.
C:\Users\Curtis\OneDrive\文件\Arduino\sketch_aug19a\sketch_aug19a.ino:1:10: fatal error: DHT11.h: No such file or directory
compilation terminated.
exit status 1
Compilation error: DHT11.h: No such file or directory
Please help!
did you install DHT11 library in library manager?
I installed multiple variants of the library and tested them 1 by 1 but none of them worked
before attempting to implement a project using multiple devices test each device in a separate program
e.g. using Tools>Manage Libraries install a DHT11 library
then compile, link and load the library example programs, e.g. Edit>Examples>DHT11>ReadTemperature
test any other sensors in a similar manner
once you know how to use the libraries and you know the sensors work you can start implementing your project
what microcontroller are you using?
To interface DHT11 sensor with Arduino checkout this guide: https://playwithcircuit.com/how-to-interface-dht11-and-dht22-sensors-with-arduino-uno/
Thanks a lot, horace and jrchana! It worked after I treid your methods.
