Please don't tell me Radio Shack. Radio Shack went backrupt about 5 years ago and was completly replaced with other "retailers". (maybe that is just in my country...or its a conspiracy and they never ceased to exist!)
Recycled part perhaps? Just looking for some ideas.
My last project a 5x5x5 led cube, I used a old wooden cigar box found at a thrift store. Led array mounts on top and all the electronics mounts inside the hinged top. Easy to drill holes in the back for switches and power jacks, etc.
I often use transparent boxes made for foodstuffs or other household things (sorry, I don't know many correct household terms
They come in all sizes and qualities. They have two drawbacks:
many are much too "floppy"
they are rarely rectangular
The trick is to use them upside down: I screw or glue a work plate onto the top, and close it with the transparent main part.
The work plate can be a strip board e.g.; epoxyd is much better for this than pertinax.
The boxes I use are between $2 and $5... But they do come in all sizes !
...to be particularly interesting; their 0.2 liter box and lid can hold an Arduino Duemilanove (without a shield), while their 0.3 liter box and lid will hold one with a shield, maybe even two shields. One would have to, of course, modify the boxes to allow for mounting of the Arduino, and access to the USB and power plug...
A few interesting things about the boxes:
The design, especially with the lid on and snapped closed, is very rigid, and resists flexing
The lid includes holes, which line up with holes on the folding snaps, which could allow for screws to secure the lid shut
Easily worked polypropylene plastic, in a variety of transparent colors, clear, and solid black
I've been using their 0.07 and 0.2 litre boxes for stand-alone projects. You can fit in two AA batteries and a bit of electronics. Staples and Office Depot carry them here.
I've also used 3xAA battery cages. I gut the middle battery slot for the electronics. You can get battery cages with a built-in on/off switch. Drill holes for the bits that show through (like LEDs) and, voila, a nice hand-held box complete with an off switch.
I make a lot of my cases from wood. I also size some of my boards to fit in Altoids tins.
Almost all the wood I use is reclaimed from trees in my yard or from construction-site dumpsters.
In Ontario their are several physical store front companies including:
*Sayal my favourite has several Ontario locations . . . all with a VERY good assortment of boxes . . . note that the stores are great, but their web site sucks www.sayal.com
*Creatron in downtown Toronto has a FANTASTIC selection of Auduino and associated accessories like shields and xBee modules of every sort
*Active Electronics has several Ontario locations
*Active Surplus in downtown Toronto . . . you never know what you will find here and stock changes so buy if you like it now, cause it will not be there the next time you come.
*KW Surplus in Kitchener, Ontario where you will also need to buy it when you see it if you like it
(no web site)
NOTE that Creatron and Active Surplus are located just a few blocks from each other in Toronto, so if you go to one . . . make the pilgramage to the other at the same time
BTW - Radio Shack was replaced with a crappy chain called The Source, and they still carry a few project boxes . . . keep an eye out, because they frequently clear out their inventory of electronic components by offering knobs, buttons, switches . . . and boxes . . . at 50-70% off. I am sure that they will be completely out of the small component business within a year or two.
