Project delay issue
Hello, I am working on a project that uses an ultrasonic sensor, buzzer, vibration motor and a micro servo. The servo and the ultrasonic sensor are supposed to be functioning constantly at the same time. The ultrasonic sensor is supposed to turn on the buzzer and vibration motor as soon as it detects something in range.
Since you cant have two void loops I put the two functions into one loop, shown in my code below in the batch code, the problem I am facing is that when I program it the ultrasonic has an extreme delay in its detection, around 6 sec, and that delay also applies to the buzzer and vibration motor, they keep working for a good 6 sec even when the object has been removed from the sight of the ultrasonic.
However when I program the servo and the ultrasonic along with the buzzer and the vibration motor they work perfectly. The individual codes are shown below along with the combined code.
batch code:
#define trigPin 13
#define echoPin 12
#define motor 7
#define buzzer 6
#include <Servo.h>
Servo myservo; // create servo object to control a servo
int pos = 0; // variable to store the servo position
{ pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(motor, OUTPUT);
pinMode(buzzer,OUTPUT);
  myservo.attach(9); // attaches the servo on pin 9 to the servo object
void loop(){
  Sonic();
  Servo();
myservo.write(45); // tell servo to go to position in variable 'pos'
  delay(2000);
void Sonic()
{ long duration, distance;
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
if (distance < 70) // Checking the distance, you can change the value
digitalWrite(motor,HIGH); // When the the distance below 100cm
digitalWrite(buzzer,HIGH);
} else
digitalWrite(motor,LOW);// when greater than 100cm
digitalWrite(buzzer,LOW);
} delay(500);
void Servo()
  delay(2000);
  for(pos = 45; pos <= 135; pos += 3) // goes from 45 degrees to 135 degrees
  { // in steps of 1 degree
    myservo.write(pos); // tell servo to go to position in variable 'pos'
    delay(100); // waits 15ms for the servo to reach the position
  for(pos = 135; pos>=45; pos-=3) // goes from 135 degrees to 45 degrees
Servo Code:
#include <Servo.h>
  delay(2000);
Ultra sonic:
#define trigPin 13
#define echoPin 12
#define motor 7
#define buzzer 6
} else
} delay(100);
Get rid of all the delay() in your code. That stops the program from doing anything useful.
Please edit your post and add </> code tags.
<< thanks >>
The demo Several Things at a Time illustrates the use of millis() to manage timing without blocking. It may help with understanding the technique.
Have a look at Using millis() for timing. A beginners guide if you need more explanation.
...R
