Project ESP8266 BMP180 & ThingSpeak
Hello everyone i am trying to make a code for my esp8266 with an bmp180 and i cannot upload to mi thingspeak account because it cause error when i upload the code.
i am trying to make a simple viewer for mi house of the temp and pressure and i can't go forward.
can anyone help me?
cheers
#include <Wire.h>           //Cargamos la librería Wire
#include <Adafruit_BMP085.h>//Cargamos la librería BMP085
#include <ESP8266WiFi.h>
 Adafruit_BMP085 bmp;           //Iniciamos una instancia de la librería BMP085
String apiKey = "api code";     //  Enter your Write API key from ThingSpeak
const char* ssid =  "wifi";     // Enter your WiFi Network's SSID
const char* pass =  "password"; // Enter your WiFi Network's Password
const char* server = "api.thingspeak.com";
float temp;
float pres;
float Altitud;
float sea;
WiFiClient client;
       delay(10);
       if (!bmp.begin()) {  //Si hay un error al iniciar la librería...
  Serial.println("No se puede iniciar el sensor BMP085, compruebe las conexiones!"); //Mostramos un mensaje
  while (1) {} //Detenemos la ejecución
       Serial.println("Connecting to ");
       Serial.println(ssid);
       WiFi.begin(ssid, pass);
      while (WiFi.status() != WL_CONNECTED)
            delay(100);
            Serial.print("*");
      Serial.println("");
      Serial.println("***WiFi connected***");
      temp = bmp.readTemperature()
      pres = bmp.readPressure()
      Altitud = bmp.readAltitude();
      sea = bmp.readSealevelPressure()
      if (client.connect(server,80))   //   "184.106.153.149" or api.thingspeak.com
       String sendData = apiKey+"&field1="+String(temp)+"&field2="+String(pres)++"&field3="+String(Altitud)+"&field4="+String(sea)+"\r\n\r\n";
       //Serial.println(sendData);
       client.print("POST /update HTTP/1.1\n");
       client.print("Host: api.thingspeak.com\n");
       client.print("Connection: close\n");
       client.print("X-THINGSPEAKAPIKEY: "+apiKey+"\n");
       client.print("Content-Type: application/x-www-form-urlencoded\n");
       client.print("Content-Length: ");
       client.print(sendData.length());
       client.print("\n\n");
       client.print(sendData);
    //Leemos los valores del sensor y sacamos la temperatura por el monitor serie
    Serial.print("Temperatura = ");
    Serial.print(bmp.readTemperature());
    Serial.println(" *C");
    //Leemos los valores del sensor y sacamos la presión atmosférica por el monitor serie
    Serial.print("Presión = ");
    Serial.print(bmp.readPressure());
    Serial.println(" Pa");
    //Calculamos la altitud asumiendo la presión barométrica 'standard' a 1013.25 milibares
    Serial.print("Altitud = ");
    Serial.print(bmp.readAltitude());
    Serial.println(" metros");
    //Calculamos la presión a nivel del mar usando una función de la librería
    Serial.print("Presión a nivel del mar (calculada) = ");
    Serial.print(bmp.readSealevelPressure());
      client.stop();
      Serial.println("Sending....");
 delay(10000);
Replace password with your password
Replace wifi with your wifi ssid
All btrween quote marks as shown
dave-in-nj:
yes i know haha
but i delete that to not show my ids.
the arduino ide shows this error
C:\Users\santi\Google Drive\Arduino\Esp8266_thingspeak_DHT11\Esp8266_thingspeak_DHT11.ino: In function 'void setup()':
Esp8266_thingspeak_DHT11:45:1: error: a function-definition is not allowed here before '{' token
Esp8266_thingspeak_DHT11:96:1: error: expected '}' at end of input
exit status 1
[pre][code]String apiKey = "***";     //  hidden -   Write API key from ThingSpeak
const char* ssid =  "***";     // hidden -   WiFi Network's SSID
const char* pass =  "***"; // hidden  WiFi Network's Password
[/pre]
[/code]
"***" tells us without revealing
need to close void setup !
       delay(10);
            delay(100);
            Serial.print("*");
      Serial.println("");
}  // end of   if (!bmp.begin())
/*  what goes here ??? */
