Here is the code:
#include <Keypad.h>
#include<LiquidCrystal.h>
#include<EEPROM.h>
#include <SPI.h>
#include <SD.h>
File myFile;
LiquidCrystal lcd(9,8,7,6,5,4);
char password[4];
char pass[4],pass1[4];
int i=0;
char customKey=0;
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
char hexaKeys[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
byte rowPins[ROWS] = {A0,A1,A2,A3}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {A4,A5,3,2}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
int led;
int buzzer = 10;
int m11;
int m12;
pinMode(11, OUTPUT);
lcd.begin(16,2);
pinMode(led, OUTPUT);
pinMode(buzzer, OUTPUT);
pinMode(m11, OUTPUT);
pinMode(m12, OUTPUT);
lcd.print(" Electronic ");
Serial.print(" Electronic ");
lcd.setCursor(0,1);
lcd.print(" Keypad Lock ");
Serial.print(" Keypad Lock ");
delay(2000);
lcd.clear();
lcd.print("Enter Ur Passkey:");
Serial.println("Enter Ur Passkey:");
lcd.setCursor(0,1);
for(int j=0;j<4;j++)
EEPROM.write(j, j+49);
pass[j]=EEPROM.read(j);
digitalWrite(11, HIGH);
customKey = customKeypad.getKey();
if(customKey=='#')
change();
if (customKey)
password[i++]=customKey;
lcd.print(customKey);
Serial.print(customKey);
beep();
if(i==4)
delay(200);
if(!(strncmp(password, pass,4)))
digitalWrite(led, HIGH);
beep();
lcd.clear();
lcd.print("Passkey Accepted");
Serial.println("Passkey Accepted");
digitalWrite(11, LOW);
delay(2000);
lcd.setCursor(0,1);
lcd.print("#.Change Passkey");
Serial.println("#.Change Passkey");
delay(2000);
lcd.clear();
lcd.print("Enter Passkey:");
Serial.println("Enter Passkey:");
lcd.setCursor(0,1);
i=0;
digitalWrite(led, LOW);
digitalWrite(buzzer, HIGH);
lcd.clear();
lcd.print("Access Denied...");
Serial.println("Access Denied...");
lcd.setCursor(0,1);
delay(2000);
lcd.clear();
lcd.setCursor(0,1);
i=0;
digitalWrite(buzzer, LOW);
void change()
int j=0;
lcd.clear();
lcd.print("UR Current Passk");
Serial.println("UR Current Passk");
lcd.setCursor(0,1);
while(j<4)
char key=customKeypad.getKey();
if(key)
pass1[j++]=key;
lcd.print(key);
Serial.print(key);
beep();
key=0;
if((strncmp(pass1, pass, 4)))
lcd.clear();
lcd.print("Wrong Passkey...");
Serial.println("Wrong Passkey...");
lcd.setCursor(0,1);
lcd.print("Better Luck Again");
Serial.println("Better Luck Again");
j=0;
lcd.clear();
lcd.print("Enter New Passk:");
Serial.println("Enter New Passk:");
lcd.setCursor(0,1);
while(j<4)
if(key)
pass[j]=key;
lcd.print(key);
Serial.print(key);
EEPROM.write(j,key);
j++;
beep();
lcd.print(" Done......");
Serial.println(" Done......");
lcd.clear();
lcd.print("Enter Ur Passk:");
Serial.println("Enter Ur Passk:");
lcd.setCursor(0,1);
customKey=0;
void beep()
delay(20);
The struggling is when i start with the SD card. I don't know how to do it. I was tried with that after void setup, but doesn't work:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
if (!SD.begin(10)) {
Serial.println("initialization failed!");
while (1);
Serial.println("initialization done.");
// open the file for reading:
myFile = SD.open("test.txt");
if (myFile) {
Serial.println("test.txt:");
// read from the file until there's nothing else in it:
while (myFile.available()) {
Serial.write(myFile.read());
// close the file:
myFile.close();
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
// nothing happens after setup
