First of all, to say that I am quite new and so I am quite lost in the language of Arduino.
I am immersed in my personal project which is to create a gearshift indicator to connect it to a steering wheel of PS4.
Look on the internet, I got a code and I modified it to make the gears, neutral and reverse. So far so good.
As I use it with different cars, some have a maximum of 4 gears, another 5, and so on. I would like to select the maximum number of marches to display using a dial that activates the different Arduino ports. For example: if pin 11 reads HIGH, limit the number of gears to 4, if pin 12 reads HIGH, the number of gears is 5, and so on.
I´ve tried some instructions, I couldn´t get it working.
The code I´m using is:
#define BUTTON_DOWN 9
#define BUTTON_UP 10
int ledPinA = 2; // LED connected to digital pin 3
int ledPinB = 3; // LED connected to digital pin 4
int ledPinC = 4; // LED connected to digital pin 5
int ledPinD = 5; // LED connected to digital pin 6
int ledPinE = 6; // LED connected to digital pin 7
int ledPinF = 7; // LED connected to digital pin 8
int ledPinG = 8; // LED connected to digital pin 9
int val_down = 0;
int old_val_down = 0;
int val_up = 0;
int old_val_up = 0;
int state = 0;
int gear = 1;
pinMode(BUTTON_DOWN, INPUT_PULLUP);
pinMode(BUTTON_UP, INPUT_PULLUP);
pinMode(ledPinA, OUTPUT);
pinMode(ledPinB, OUTPUT);
pinMode(ledPinC, OUTPUT);
pinMode(ledPinD, OUTPUT);
pinMode(ledPinE, OUTPUT);
pinMode(ledPinF, OUTPUT);
pinMode(ledPinG, OUTPUT);
void led0()// r
digitalWrite(ledPinA, LOW);
digitalWrite(ledPinB, LOW);
digitalWrite(ledPinC, LOW);
digitalWrite(ledPinD, LOW);
digitalWrite(ledPinE, HIGH);
digitalWrite(ledPinF, LOW);
digitalWrite(ledPinG, HIGH);
void led1()// n
digitalWrite(ledPinC, HIGH);
void led2()//1
digitalWrite(ledPinB, HIGH);
digitalWrite(ledPinE, LOW);
digitalWrite(ledPinG, LOW);
void led3()//2
digitalWrite(ledPinA, HIGH);
digitalWrite(ledPinD, HIGH);
void led4()//3
void led5()//4
digitalWrite(ledPinF, HIGH);
void led6()//5
void led7()//6
void led8()//7
void led9()
void setLed(int number)
switch (number) {
case 0:
led0();
case 1:
led1();
case 2:
led2();
case 3:
led3();
case 4:
led4();
case 5:
led5();
case 6:
led6();
case 7:
led7();
case 8:
led8();
case 9:
led9();
void oldloop()
// wait for a second
led0();
delay(1000); // wait for a second
led1();
led2();
led3();
led4();
led5();
led6();
led7();
led8();
led9();
val_up = digitalRead(BUTTON_UP);
if ((val_up == HIGH) && (old_val_up == LOW)&&gear<8 )
gear += 1;
delay(250);
old_val_up = val_up;
val_down = digitalRead(BUTTON_DOWN);
if ((val_down == HIGH) && (old_val_down == LOW)&&gear>1 )
gear -= 1;
delay(250);
else if ((val_down == HIGH) && (old_val_down == LOW)&&(gear<1))
gear += 1;
delay(250);
else if ((val_down == HIGH) && (old_val_down == LOW))
gear += -1;
delay(250);
old_val_down = val_down;
setLed(gear);
Thanks in advance!
