Project guidance
Hello Everyone,
I'm Eddie, mewbie here. I have been working with a friend of mine who programs LED's using Arduino's quite often. I've come to a sort of question. I've seen some people on youtube and other places use their LED's to simulate a "lightning" effect. The downside is that it seems like they are using 12v LED strips and i have 5v LED strips wired. Would it be possible to do the below?
On/off switch to light all 288 LED's one solid color
Push button switch to make the lightning effect
I have attached my wiring scheme and here is a link to the LED's i have wired.
What is the problem with using 5V LEDs as opposed to 12V LEDs ?
OPs image...
No problem doing what you want, just keep track of your LED power supply.
So below is the sketch i found. I wouldnt need the sound. I showed it to my buddy and he said it wouldnt work because of the difference in LED's.
#include "Arduino.h"
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
int ledPin = 9; // LEDs (via MOSFET) connected to pin 9
int rxPin = 10; // DFplayer RX to Arduino pin 10
int txPin = 11; // DFplayer TX toArduinopin 11
int busyPin = 12; // DFplayer BUSY connected to pin 12
SoftwareSerial mySoftwareSerial(rxPin, txPin);
DFRobotDFPlayerMini myDFPlayer;
pinMode(ledPin, OUTPUT);
pinMode(busyPin, INPUT);
mySoftwareSerial.begin(9600);
Serial.println(F("Initializing DFPlayer..."));
if (!myDFPlayer.begin(mySoftwareSerial)) { //Use softwareSerial to communicate with mp3.
Serial.println(F("Unable to begin. Check connection and SD card, or reset the Arduino."));
while (true);
Serial.println(F("DFPlayer Mini online."));
myDFPlayer.setTimeOut(500); // Set serial communictaion time out 500ms
myDFPlayer.volume(30); // Set volume value (0~30).
myDFPlayer.EQ(DFPLAYER_EQ_BASS); // Set EQ to BASS (normal/pop/rock/jazz/classic/bass)
myDFPlayer.outputDevice(DFPLAYER_DEVICE_SD); // Set device we use SD as default
myDFPlayer.enableDAC(); // Enable On-chip DAC
int flashCount = random (3, 15); // Min. and max. number of flashes each loop
int flashBrightnessMin = 10; // LED flash min. brightness (0-255)
int flashBrightnessMax = 255; // LED flash max. brightness (0-255)
int flashDurationMin = 1; // Min. duration of each seperate flash
int flashDurationMax = 50; // Max. duration of each seperate flash
int nextFlashDelayMin = 1; // Min, delay between each flash and the next
int nextFlashDelayMax = 150; // Max, delay between each flash and the next
int thunderDelay = random (500, 3000); // Min. and max. delay between flashing and playing sound
int thunderFile = random (1, 17); // There are 17 soundfiles: 0001.mp3 ... 0017.mp3
int loopDelay = random (5000, 30000); // Min. and max. delay between each loop
Serial.print(F("Flashing, count: "));
Serial.println( flashCount );
for (int flash = 0 ; flash <= flashCount; flash += 1) { // Flashing LED strip in a loop, random count
analogWrite(ledPin, random (flashBrightnessMin, flashBrightnessMax)); // Turn LED strip on, random brightness
delay(random(flashDurationMin, flashDurationMax)); // Keep it tured on, random duration
analogWrite(ledPin, 0); // Turn the LED strip off
delay(random(nextFlashDelayMin, nextFlashDelayMax)); // Random delay before next flash
Serial.print(F("Pausing before playing thunder sound, milliseconds: "));
Serial.println(thunderDelay);
delay(thunderDelay);
Serial.print(F("Playing thunder sound, file number: "));
Serial.println(thunderFile);
myDFPlayer.playMp3Folder(thunderFile);
delay(1000); // Give the DFPlayer some time
while (digitalRead(busyPin) == LOW) { // Wait for the DFPlayer to finish playing the MP3 file
Serial.print(F("Pausing before next loop, milliseconds: "));
Serial.println(loopDelay);
delay(loopDelay);
Exactly what type of LEDs do you have ?
Assuming you're using 2x 144-pixel Neopixel strips, you can try this. It's lightning logic is based on the code you showed but adapted (hopefully!) for the Neopixel. It compiles but I have no idea if it works.
#define SW_READ_INTERVAL        50ul            //mS    time between button reads (minimum)
const uint16_t  numLEDs = 288;                  //#     number of LEDs in Neopixel strip
const byte pinLEDs = 6;                         //pinNo pin number of dataline to Neopixels
const byte pinSW = 9;                           //pinNo pin number of button/switch
const byte flashNumMin =  3;                    //#     minimum number of flashes per sequence
const byte flashNumMax =  9;                    //#     maximum number of flashes per sequence
const byte flashBrightnessMin =  10;            //#     minimum brightness of flash
const byte flashBrightnessMax =  255;           //#     maximum brightness of flash
const int flashDurationMin = 1;                 //mS    minimum duration of flash
const int flashDurationMax = 50;                //mS    maximum duration of flash
const int flashDelayMin = 1;                    //mS    minimum period between flashes
const int flashDelayMax = 150;                  //mS    maximum period between flashes
byte lSw;
Adafruit_NeoPixel neoPix = Adafruit_NeoPixel( numLEDs, pinLEDs, NEO_GRB + NEO_KHZ800);
    //init the neoPix object
    neoPix.begin();
    //and set the switch input mode
    pinMode( pinSW, INPUT_PULLUP );
    //establish current switch status
    lSw = digitalRead( pinSW );
}//setup
    //run the state machine every loop
    LightningStateMachine();
}//loop
//state names
#define WAIT_BUTTON     0
#define FLASH_LIGHTNING 1
#define TURN_ON         0
#define TIME_ON         1
#define TIME_OFF        2
void LightningStateMachine( void )
    byte
        nSw;
    static int
        flashCount;
    static unsigned long
        timeLightning,
        timeLightningDelay,
        tSw;
    unsigned long
        tNow;
    static byte
        flashBright,
        stateFlash = TURN_ON,
        stateLightning = WAIT_BUTTON;
    tNow = millis();
    switch( stateLightning )
        case    WAIT_BUTTON:
            //check for the button pin to go from high to low
            if( (tNow - tSw) >= SW_READ_INTERVAL )
                tSw = tNow;
                nSw = digitalRead( pinSW );
                if( nSw != lSw )
                    //not the same as last time...
                    lSw = nSw;
                    //is it low now?
                    if( nSw == LOW )
                        //yes; button was pushed.
                        //set up the number of flashes and then move to the FLASH state
                        flashCount = random( flashNumMin, flashNumMax );
                        stateLightning = FLASH_LIGHTNING;
                    }//if
                }//if
            }//if
        case    FLASH_LIGHTNING:
            //if we're done flashes...
            if( flashCount == 0 )
                //...init the button read timer and then move back to read the button again
                tSw = tNow;
            }//if
                //for flashing the lightning, our states are...
                switch( stateFlash )
                    case    TURN_ON:
                        //turn on the strip at a random brightness and for a random time...
                        timeLightningDelay = (unsigned long)random( flashDurationMin, flashDurationMax );
                        flashBright = random( flashBrightnessMin, flashBrightnessMax );
                        uint32_t fillcol = neoPix.Color( flashBright, flashBright, flashBright );
                        neoPix.fill( fillcol, 0, neoPix.numPixels() );
                        //...and show it
                        neoPix.show();
                        //set up to time the on-time and move that state
                        timeLightning = millis();
                        stateFlash = TIME_ON;
                    case    TIME_ON:
                        //we're timing the on-time of the flash...
                        if( (tNow - timeLightning) >= timeLightningDelay )
                            //once done, turn off the strip...
                            neoPix.clear();
                            neoPix.show();
                            //and set up for a random interflash delay
                            timeLightning = tNow;
                            timeLightningDelay = (unsigned long)random( flashDelayMin, flashDelayMax );
                            //then move to time that
                            stateFlash = TIME_OFF;
                        }//if
                    case    TIME_OFF:
                        //when the interflash delay is done...
                            //we're done one more flash; decrement the flash count...
                            flashCount--;
                            //and go back and light it up again
                            stateFlash = TURN_ON;
                        }//if
                }//switch
            }//else
    }//switch
}//LightningStateMachine
thank you for taking the time to put this together. I tried this code. when i push the button with this code, it starts the flash but its so minimal. You have to like squint your eyes to see that it may be flashing.
Loleddie:
Try playing with these constants:
As experiments, you might try:
  • making the minimum brightness 200 or something, just as an experiment, and
  • making the min flash duration 100mS and the max 500mS, again as an experiment.
If the results are promising, maybe make the limits a bit lower until you're happy with the result.
Are you using 800kHz-capable Neopixels (2812) or the 400kHz ones (2811)?
