Hello all,
I am working on a project connecting multiple Arduinos in different locations across the world. The way I have it set up right now, one Arduino (attached to a ship bell) acts as a server that loads a webpage. The other Arduino is attached to a push button switch, and when pushed will send a get request to the webpage, activating the first Arduino and ringing the bell via a servo motor. This all works fine together so far.
The issue with this system is that I need to have several “bell” Arduinos. I was planning to just have each “bell” Arduino be a different server, and have the “button” Arduino send out multiple get requests at once, but I can’t figure out how to get the “button” Arduino to connect to more than one server at a time.
Is there an easier way to do what I’m doing? Does anyone know how to connect a single EthernetClient to multiple EthernetServers?
I’ve attached the code I’m using below. Note that some of the code I’m using isn’t mine, it’s compiled from projects i’ve seen around the internet. I don’t know specifically who wrote them, but I’m not claiming any of it as my own.
“Button” Arduino Code:
#include <Ethernet.h>
#include <SPI.h>
#include <Client.h>
int buttonInput = 7;
int buttonState = 0;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 10, 250, 1, 80 };
byte gateway[] = { 10, 250, 0, 1 };
byte server[] = { 10, 250, 4, 80 }; // server id
EthernetClient client;
bool connected = false;
Ethernet.begin(mac, ip, gateway);
pinMode(buttonInput, INPUT);
//digitalWrite(buttonInput, HIGH);
Serial.println("connecting...");
if (client.connect(server,80)) {
buttonState = digitalRead(buttonInput);
Serial.println("connected"); }
if (buttonState == LOW) {
if (buttonState == HIGH) {
client.print("GET /?button2off");
Serial.print("GET /?button2off");
client.println(" HTTP/1.1");
Serial.println(" HTTP/1.1");
client.println("Host: http://localhost/PhpProject1/");
Serial.println("Host: http://localhost/PhpProject1/");
client.println("User-Agent: Arduino");
Serial.println("User-Agent: Arduino");
client.println();
client.stop();
//else {
delay(900);
if (client.available()) {
char c = client.read();
Serial.print("fine");
//client.stop();
connected = false;
“Bell” Arduino Code:
#include <SPI.h>
#include <Servo.h>
Servo microservo;
int pos = 0;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xEF }; //physical mac address
byte ip[] = { 10, 250, 1, 80}; // ip in lan (that's what you need to use in your browser. ("192.168.1.178")
byte gateway[] = { 10, 250, 0, 1 }; //internet access via router
//byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(80); //server port
String readString;
// pinMode(led, OUTPUT);
microservo.attach(7);
// start the Ethernet connection and the server:
server.begin();
// Create a client connection
if (client) {
while (client.connected()) {
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.println(readString); //print to serial monitor for debuging
client.println("HTTP/1.1 200 OK"); //send new page
client.println("Content-Type: text/html");
client.println();
client.println("<HTML>");
client.println("<HEAD>");
client.println("<meta name='apple-mobile-web-app-capable' content='yes' />");
client.println("<meta name='apple-mobile-web-app-status-bar-style' content='black-translucent' />");
client.println();
client.println("<TITLE>Arduino Control Room</TITLE>");
client.println("</HEAD>");
client.println("<BODY>");
client.println("<H1>Arduino Control Room</H1>");
client.println("<hr />");
client.println("
client.println("<H2>Arduino with Ethernet Shield</H2>");
client.println("
client.println("<a href=\"/?button2off\"\">Rotate</a>
client.println("<p>Created by Mike O'Dell.</p>");
client.println("
client.println("</BODY>");
client.println("</HTML>");
delay(5);
//stopping client
client.stop();
//controls the Arduino if you press the buttons
if (readString.indexOf("?button2off") >0){
//for(pos = 180; pos>=1; pos-=3) // goes from 180 degrees to 0 degrees
microservo.attach(7,544,2400);//Pulse Values for a HiTec Servo
//microservo.write(9); // set servo to 0
microservo.write(180);
delay(600);
microservo.detach();
//clearing string for next read
readString="";
Thank you for the help!
