project help needed
Hello There,
I am trying to program my arduino uno
with a serie of 6 red leds on output 2-7 to
sequintially go on/off in one direction (this I got)
and in the reverse direction the even LEDs blink twice and
the uneven LEDS blink once. (in my model all the leds blink twice and I cant find the command to skip the odd numbers)
this is what I have:
int timer = 300; // The higher the number, the slower the timing.
{ // use a for loop to initialize each pin as an output:
for (int thisPin = 2; thisPin < 8; thisPin++)
pinMode(thisPin, OUTPUT);
{ // loop from the lowest pin to the highest:
for (int thisPin = 2; thisPin < 8; thisPin++) {
// turn the pin on:
digitalWrite(thisPin, HIGH);
delay(timer); // turn the pin off:
digitalWrite(thisPin, LOW);
delay(timer);
// loop from the highest pin to the lowest:
for (int thisPin = 7; thisPin >= 2; thisPin--)
if(thisPin = // turn the pin on:
delay(timer);
digitalWrite(thisPin, HIGH); // turn the pin on:
delay(timer);
digitalWrite(thisPin, LOW); // turn the pin off:
delay(timer);
thanks in advance,
e
When posting code select it and hit the # icon.
It is not too late you can go back and modify your post.
in the mean time what is this?
Will it compile?
Exactly what do you want to do?
you can find an odd number by looking at the least significant bit with a bitwise and operation &
if( (thisPin & 1 ) == 0) { // the number is even else it is odd
