I designed an automatic car that could follow the black traces on the white ground. The Raspberry Pi board is the brain of this system. And the Picamera, which is attached to the Raspberry Pi, can be considered as the eyes of the car. It faces the ground and collects images/video data in real-time. Then the Raspberry Pi board decides to turn right, turn left, or keep going straight by analyzing the obtained image data. After that, the Raspberry Pi sends its decision to the Arduino board via SPI protocol. Arduino converts the received steering information into the voltage value applied to the L298n motor.
here is the code I have for the Arduino, I need help writing the python code for raspberry pi using the SPI protocol to connect the two.
int rightforward =10;
int leftforward = 9;
int const ENA = 6;
int const ENB = 5;
int leftreverse = 8;
int rightreverse = 11;
//setup output pin
pinMode(leftreverse, OUTPUT);
pinMode(rightreverse, OUTPUT);
pinMode(rightforward, OUTPUT);
pinMode(leftforward, OUTPUT);
pinMode(ENA, OUTPUT);
pinMode(ENB, OUTPUT);
//forward direction
digitalWrite(leftreverse, LOW);
digitalWrite(rightforward, LOW);
digitalWrite(leftforward, HIGH);
digitalWrite(rightforward, HIGH);
//turning right
digitalWrite(leftforward,HIGH);
digitalWrite(ENA, HIGH);
digitalWrite(ENB, HIGH);
//turning left
digitalWrite(leftforward, LOW);
//going straight
here is the code I have for the raspberry pi,
import time
import numpy as np
import cv2
import smbus2 as smbus
from picamera import PiCamera
ard = 0x8 //arduino address
bus = smbus.SMBus(1)
with PiCamera() as src:
src.resolution =(640,480)
src.framerate = 30
src.shutter_speed = 75000
output = np.empty((480,640, 3), dtype=np.uint8)
while(True):
start_time = time.time()
src.capture(output, format='bgr', use_video_port=True)
gray = cv2.cvtColor(output, cv2.COLOR_BGR2GRAY)
gray[gray < 50] =0
gray[gray > 50] = 255
direction=''
top_center = np.average(np.where(gray[0] ==0 ))
bottom_center = np.average(np.where(gray[-1] ==0))
if top_center - bottom_center > 25:
print("Turn right")
direction = '1'
elif top_center - bottom_center <-25:
print("Turn left")
direction = '2'
else:
print("Stay")
direction = '3'
cv2.imshow('Output', gray)
key = cv2.waitKey(1)&0xFF
if key==ord("q"):
break
