Hi, First post but not new. Id like to throw this out and see what you guys think is do-able.
I already own a Uno but dont think it will surfice. Im not sure if its possible with Arduino...maybe Raspbery Pi?
The end result will be a touch screen set up with a snazy UI cool icons etc. What I want to include is....
---------------Monitor--------------
Tyre pressure monitor
Door open monitor
Various engine systems monitoring
Tank level indicators (its a Motorhome "RV")
More items that I cant think of right now.
---------------Control--------------
operate Door locks
operate lights
operate Air Conditioning (rear of vehicle not engine driven AC)
More items to be added but just to give an idea.
Now I know I can go 2 ways either through OBD2 or wire direct to everything. 1st problem is the RV used to be a Royal Mail truck its made in Itialy so the electroncs are dodgy to say the least... Id rather wire up directly (via relays) to each part of the system because it being made by IVECO TRUCKS its not easy to interface with the OBD2 as its based on a truck system and you cant just plug in a ebay reader and expect it to work... IT WONT! it has a 32pin round connector and just the adaptor to standard connector is about £60.
---------------Equipment--------------
Arduino (......?)
TFT LCD Touch screen 7" (plus a way to hook it up)
Relays
Anything else? Im writing this quite late my mind is a little blank!
There are more things I could hook up but one project with in the main project at a time. So what do you think will work? any idea of what system I should use? Coding it will be a learning curve but one i will take with a pinch of patience!
