Project idea
HI,
currently i am trying to find a way to record data moving along a cable between and electronic lock and its programmer (I am trying to find a work around to a problem we are currently having) i have tried to do a bit of research on it but i cant find any results so far
the only detail i have so far is that the lock is coded in E language using a pre-programmed E-Prog to do its programming
for now i am just working on the idea i might be able to reproduce the signals going out to replace the original programmer (as it is no longer being produced anymore) with a simpler device if not a program running off of a laptop or something similar
not sure if i have explained myself very well so basically i'm looking to capture the data being transferred and log it into a document on my laptop
and was wondering if the arduino would be capable
Thanks everyone!
Rowan
Do you have a link to some detail about this lock?
The best way to do something like this is using the proper tools. The bus-pirate or a logic analyzer comes to mind. There is a simple LA project using an arduino here: http://arduino.cc/forum/index.php?topic=52881.0
Is this one wire, two wire, 3 wire for comms?
so the lock is a Lagard 33E
http://www.lagard.com.au/electronic_lockingbolt_opts.html
that is there site but there isn't any detail on there site as it is a security product, but i can tell you the comms port is a 4 pin plug
thanks for your reply
Rowan
