Project:"KIDS KITCHEN Oven THAT SAYS BEEP" help needed
i found this mini project online but the arduino program wouldn't execute and i couldn't figure out the problem,here is the code and the error is (exit status 1
'tmElements_t' does not name a type) and the link of the project is bellow the code please help
#include <DS1307RTC.h>
#include <Timer.h>
#include <TM1637Display.h>
#include <Wire.h>
 *  IKEA DUKTIG clock/timer - Roald Hendriks, January 2018      *
 *  Hardware: Arduino Uno R3 / Arduino Nano                     *
 *            LEDstrips (in oven and over counter)              *
 *            DS3231 SDA analog pin4, SCL analog pin5           *
 *            TM1637 4 digit LED Display                        *
 *            4 buttons (+, -, start, stop)                     *
 *            Buzzer                                            *
// Segments for showing BEEP
const uint8_t SEG_BEEP[] = {
 SEG_A | SEG_B | SEG_C | SEG_D | SEG_E | SEG_F | SEG_G, // B
 SEG_A | SEG_D | SEG_E | SEG_F | SEG_G,                 // E
  SEG_A | SEG_B | SEG_E | SEG_F | SEG_G,                 // P
// Definition of all digital pins
// ***** Button input pins *****
// + Button
const int PlusButtonPin = 13;
// - Button
const int MinusButtonPin = 12;
// Start Button
const int StartButtonPin = 11;
// Stop Button
const int StopButtonPin = 10;
// ***** Output pins *****
// Buzzer
const int BuzzerPin = 4;
// LED-strip in oven
const int OvenLEDPin = 5;
// TM1637 clock pin
const int TM1637CLKPin = 8;
// TM1637 data pin
const int TM1637DataPin = 7;
// PWM LED brightness
const int intLEDBrightness = 200;
// Create TM1637 object
TM1637Display display(TM1637CLKPin,TM1637DataPin);
// Create RTC time object
tmElements_t RTC_time;
// Create RTC timer objects to hold the timer
// prevTimes is used to determine whether the timer has changed
tmElements_t Timer, prevTimer;
First remember that instructables are crap. Never use them to learn things because the odds are it will be wrong.
Means that you have not installed a libiary, perhaps the DS1307RTC.h or the Timer.h
https://www.arduino.cc/en/Guide/Libraries
You use the DS1307RTC library which itself depends on the Time library by Michael Margolis (you can install them by the library manager of the IDE). With both libraries installed you shouldn't get that error.
If you still get an error, tell us which version of the libraries you installed and which version of the IDE you're running.
