Project not doing what it should (DMX and I2C communication)
i have like half of the code from it, yeah
better you say it in first post.
so, what piece is from you ?
and, is this weird idea with second arduino came from ChatGpt too?
the slave code is from me, the I2C communication, the EEPROM and for the display
i tried to do the buttons too but made some mistakes so i've let it run over the code for the buttons
all the code for dmx is gpt tho
did you tested your "slave"-sketch? does it what you expected?
i did, yeah
tested it with this code on the "master" and it did what i wanted without any problems
#include <Wire.h>
#include <math.h>
// Constants for the sine wave
const float pi = 3.14159265;
const int amplitude = 127;
const int offset = 128;
const int period = 360;
  Wire.begin();
  for (int i = 0; i < period; i++) {
    int pwmValue1 = offset + amplitude * sin((2 * pi * i) / period);
    int pwmValue2 = offset + amplitude * sin((2 * pi * (i + period / 3)) / period);
    int pwmValue3 = offset + amplitude * sin((2 * pi * (i + 2 * period / 3)) / period);
    // address 0x01
    sendPWMValues(0x01, pwmValue1, pwmValue2, pwmValue3);
    // address 0x02
    sendPWMValues(0x02, pwmValue1, pwmValue2, pwmValue3);
    delay(10);
void sendPWMValues(byte address, int value1, int value2, int value3) {
  Wire.beginTransmission(address);
  Wire.write(value1);
  Wire.write(value2);
  Wire.write(value3);
  Wire.endTransmission();
cool, use this sketch in slave and let check what shows serial monitor
#include <Wire.h>
// Definition of PWM pins
const int pwmPin1 = 3;
const int pwmPin2 = 5;
const int pwmPin3 = 6;
// Timeout constants
const unsigned long timeoutInterval = 500; // 500 ms timeout interval
unsigned long lastReceiveTime = 0; // Time of last received data
  Serial.println("start\n");
  // Set PWM pins as output
  pinMode(pwmPin1, OUTPUT);
  pinMode(pwmPin2, OUTPUT);
  pinMode(pwmPin3, OUTPUT);
  Wire.begin(0x01); // Start I2C with address 0x01
  Wire.onReceive(receiveEvent); // Register the receive event handler
  // Turn off LEDs initially
  analogWrite(pwmPin1, 0);
  analogWrite(pwmPin2, 0);
  analogWrite(pwmPin3, 0);
  // Check if timeout has been exceeded
  if (millis() - lastReceiveTime > timeoutInterval) {
    // Turn off the LEDs
void receiveEvent(int howMany) {
  int pwmValue1 = Wire.read(); // Receive PWM value for pin 1
  int pwmValue2 = Wire.read(); // Receive PWM value for pin 2
  int pwmValue3 = Wire.read(); // Receive PWM value for pin 3
  // Set PWM values for the pins
  analogWrite(pwmPin1, pwmValue1);
  analogWrite(pwmPin2, pwmValue2);
  analogWrite(pwmPin3, pwmValue3);
  // Update the time of last received data
  lastReceiveTime = millis();
  Serial.print(pwmValue1);
  Serial.print('\t');
  Serial.print(pwmValue2);
  Serial.print('\t');
  Serial.println(pwmValue3);
  Serial.flush();
this
1	181	200
1	183	199
1	185	197
1	187	195
1	189	193
1	191	191
1	193	189
1	195	187
1	197	185
1	199	183
1	200	181
1	202	179
1	204	177
2	206	175
2	207	173
2	209	171
3	211	169
3	212	167
4	214	165
4	216	163
5	217	160
5	219	158
6	220	156
7	222	154
7	223	152
8	225	150
9	226	147
10	228	145
11	229	143
11	230	141
12	232	139
13	233	136
14	234	134
15	235	132
16	236	130
18	237	128
19	239	125
20	240	123
21	241	121
22	242	119
23	243	116
25	244	114
26	244	112
27	245	110
29	246	108
30	247	105
32	248	103
33	248	101
35	249	99
36	250	97
38	250	95
39	251	92
41	251	90
43	252	88
44	252	86
46	253	84
48	253	82
49	253	80
51	254	78
53	254	76
55	254	74
56	254	72
58	254	70
60	254	68
62	254	66
64	255	64
66	254	62
68	254	60
70	254	58
72	254	56
74	254	55
76	254	53
78	254	51
80	253	49
82	253	48
84	253	46
86	252	44
88	252	43
90	251	41
92	251	39
95	250	38
97	250	36
99	249	35
101	248	33
103	248	32
105	247	30
108	246	29
110	245	27
112	244	26
114	244	25
116	243	23
119	242	22
121	241	21
123	240	20
125	239	19
128	237	18
130	236	16
132	235	15
134	234	14
136	233	13
139	232	12
141	230	11
143	229	11
145	228	10
147	226	9
150	225	8
152	223	7
154	222	7
156	220	6
158	219	5
160	217	5
163	216	4
165	214	4
167	212	3
169	211	3
171	209	2
173	207	2
175	206	2
177	204	1
179	202	1
181	200	1
183	199	1
185	197	1
187	195	1
189	193	1
191	191	1
193	189	1
195	187	1
197	185	1
199	183	1
200	181	1
202	179	1
204	177	1
206	175	2
207	173	2
209	171	2
211	169	3
212	167	3
214	165	4
216	163	4
217	160	5
219	158	5
220	156	6
222	154	7
223	152	7
225	150	8
226	147	9
228	145	10
229	143	11
230	141	11
232	139	12
233	136	13
234	134	14
235	132	15
236	130	16
237	127	18
239	125	19
240	123	20
241	121	21
242	119	22
243	116	23
244	114	25
244	112	26
245	110	27
246	108	29
247	105	30
248	103	32
248	101	33
249	99	35
250	97	36
250	95	38
251	92	39
251	90	41
252	88	43
252	86	44
253	84	46
253	82	48
253	80	49
254	78	51
254	76	53
254	74	55
254	72	56
254	70	58
254	68	60
254	66	62
255	64	64
254	62	66
254	60	68
254	58	70
254	56	72
254	55	74
254	53	76
254	51	78
253	49	80
253	48	82
253	46	84
252	44	86
252	43	88
251	41	90
251	39	92
250	38	95
250	36	97
249	35	99
248	33	101
248	32	103
247	30	105
246	29	108
245	27	110
244	26	112
244	25	114
243	23	116
242	22	119
241	21	121
240	20	123
239	19	125
237	18	128
236	16	130
235	15	132
234	14	134
233	13	136
232	12	139
230	11	141
229	11	143
228	10	145
226	9	147
225	8	150
223	7	152
222	7	154
220	6	156
219	5	158
217	5	160
216	4	163
214	4	165
212	3	167
211	3	169
209	2	171
207	2	173
206	2	175
204	1	177
202	1	179
200	1	181
199	1	183
197	1	185
195	1	187
193	1	189
191	1	191
189	1	193
187	1	195
185	1	197
183	1	199
181	1	200
179	1	202
177	1	204
175	2	206
173	2	207
171	2	209
169	3	211
167	3	212
165	4	214
163	4	216
160	5	217
158	5	219
156	6	220
154	7	222
152	7	223
150	8	225
147	9	226
145	10	228
143	11	229
141	11	230
139	12	232
136	13	233
134	14	234
132	15	235
130	16	236
127	18	237
125	19	239
123	20	240
121	21	241
119	22	242
116	23	243
114	25	244
112	26	244
110	27	245
108	29	246
105	30	247
103	32	248
101	33	248
99	35	249
97	36	250
95	38	250
92	39	251
90	41	251
88	43	252
86	44	252
84	46	253
82	48	253
80	49	253
78	51	254
76	53	254
74	55	254
72	56	254
70	58	254
68	60	254
66	62	254
64	64	255
62	66	254
60	68	254
58	70	254
56	72	254
55	74	254
53	76	254
51	78	254
49	80	253
48	82	253
46	84	253
44	86	252
43	88	252
41	90	251
39	92	251
38	95	250
36	97	250
35	99	249
33	101	248
32	103	248
30	105	247
29	108	246
27	110	245
26	112	244
25	114	244
23	116	243
22	119	242
21	121	241
20	123	240
19	125	239
18	128	237
16	130	236
15	132	235
14	134	234
13	136	233
12	139	232
11	141	230
11	143	229
10	145	228
9	147	226
8	150	225
7	152	223
7	154	222
6	156	220
5	158	219
5	160	217
4	163	216
4	165	214
3	167	212
3	169	211
2	171	209
2	173	207
2	175	206
1	177	204
1	179	202
1	181	200
1	183	199
1	185	197
1	187	195
1	189	193
1	191	191
1	193	189
1	195	187
1
so... working fine? ig
cool, then let see what this master do
#include <Wire.h>
#include <Conceptinetics.h>
#include <TM1637Display.h>
#include <EEPROM.h>
// Pins for the buttons
const int buttonMinusPin = A0; // Change to analog pin
const int buttonPlusPin = A1; // Change to analog pin
// Pins for the TM1637 Display
const int CLK = 2; // Pin for CLK
const int DIO = 3; // Pin for DIO
// Variables for the buttons
int lastButtonMinusState = HIGH;
int lastButtonPlusState = HIGH;
unsigned long lastDebounceTimeMinus = 0;
unsigned long lastDebounceTimePlus = 0;
unsigned long debounceDelay = 50;
unsigned long buttonPressStartTimeMinus = 0;
unsigned long buttonPressStartTimePlus = 0;
bool isButtonPressedMinus = false;
bool isButtonPressedPlus = false;
// DMX Slave object
#define DMX_SLAVE_CHANNELS 3 // Number of DMX channels
#define RXEN_PIN 2 // RXEN Pin (Receive enable)
DMX_Slave dmx_slave(DMX_SLAVE_CHANNELS, RXEN_PIN); // Create DMX_Slave object
// TM1637 Display object
TM1637Display display(CLK, DIO);
// EEPROM memory address for DMX address
const int eepromAddress = 0;
  Wire.begin(); // Start I2C
  pinMode(buttonMinusPin, INPUT_PULLUP);
  pinMode(buttonPlusPin, INPUT_PULLUP);
  pinMode(10, OUTPUT);  // Define pin 10 as output
  digitalWrite(10, HIGH); // Output 5V continuously
  // Initialize DMX Slave
  dmx_slave.enable(); // Enable DMX Slave
  // Read DMX start address from EEPROM
  int storedAddress = EEPROM.read(eepromAddress);
  if (storedAddress < 1 || storedAddress > 512 - DMX_SLAVE_CHANNELS + 1) {
    storedAddress = 1; // Default address if invalid address in EEPROM
  dmx_slave.setStartAddress(storedAddress); // Set DMX start address
  // Initialize TM1637 Display
  display.setBrightness(0x0f); // Maximum brightness
  // Show initial DMX address on display
  display.showNumberDec(dmx_slave.getStartAddress(), true);
  //handleButtonPresses();
  // Example: Map DMX values to PWM values and send
  int dmxAddress = 1; // Example channel 1
  int dmxValue = dmx_slave.getChannelValue(dmxAddress);
  sendPWMValues(255, 255, 255); // Example: send same PWM values to both devices
  // Example: Display DMX address on the display
  display.showNumberDec(dmxValue, true);
  // Wait a bit to control the update speed
  delay(2); // Reduce delay to update display 5x faster
void handleButtonPresses() {
  int buttonMinusState = analogRead(buttonMinusPin) < 512 ? LOW : HIGH;
  int buttonPlusState = analogRead(buttonPlusPin) < 512 ? LOW : HIGH;
  unsigned long currentTime = millis();
  // Minus button
  if (buttonMinusState == LOW && lastButtonMinusState == HIGH) {
    lastDebounceTimeMinus = currentTime;
    buttonPressStartTimeMinus = currentTime;
    isButtonPressedMinus = true;
  } else if (buttonMinusState == HIGH && lastButtonMinusState == LOW) {
    if (isButtonPressedMinus && currentTime - buttonPressStartTimeMinus >= debounceDelay) {
      int currentAddress = dmx_slave.getStartAddress();
      dmx_slave.setStartAddress(max(1, currentAddress - 1));
      EEPROM.write(eepromAddress, dmx_slave.getStartAddress()); // Save DMX start address in EEPROM
  } else if (buttonMinusState == LOW && isButtonPressedMinus && currentTime - buttonPressStartTimeMinus >= 1000) {
    unsigned long interval = map(currentTime - buttonPressStartTimeMinus, 1000, 2000, 20, 2);
    interval = max(interval, 2); // Minimum interval of 2ms
    if (currentTime - buttonPressStartTimeMinus >= interval) {
  lastButtonMinusState = buttonMinusState;
  // Plus button
  if (buttonPlusState == LOW && lastButtonPlusState == HIGH) {
    lastDebounceTimePlus = currentTime;
    buttonPressStartTimePlus = currentTime;
    isButtonPressedPlus = true;
  } else if (buttonPlusState == HIGH && lastButtonPlusState == LOW) {
    if (isButtonPressedPlus && currentTime - buttonPressStartTimePlus >= debounceDelay) {
      dmx_slave.setStartAddress(min(512 - DMX_SLAVE_CHANNELS + 1, currentAddress + 1));
  } else if (buttonPlusState == LOW && isButtonPressedPlus && currentTime - buttonPressStartTimePlus >= 1000) {
    unsigned long interval = map(currentTime - buttonPressStartTimePlus, 1000, 2000, 20, 2);
    if (currentTime - buttonPressStartTimePlus >= interval) {
  lastButtonPlusState = buttonPlusState;
void sendPWMValues(int pwmValue1, int pwmValue2, int pwmValue3) {
  Wire.beginTransmission(0x01);
  Wire.write(pwmValue1 & 0xFF); // Send low byte of PWM value for pin 1
  Wire.write(pwmValue2 & 0xFF); // Send low byte of PWM value for pin 2
  Wire.write(pwmValue3 & 0xFF); // Send low byte of PWM value for pin 3
putting this out constantly
255	255	255
255	255	255
255	255	255
255	255	255
255	255	255
so that's also how it should be for what i see
what shows display on master?
it showed 0001 for a short time but went 0000 after a few seconds and doesn't change
went to 255 now suddenly after plugging dmx out and in again
is dmx_slave.getStartAddress()
is dmx_slave.getChannelValue(dmxAddress)
k, yeah, thought so
do you can send some value thru DMX ? so it is shown in display, 222 for example?
it's receiving the signal, the display shows that
now the slave only needs to get it too
new master
#include <Wire.h>
#include <EEPROM.h>
// DMX Slave object
  sendPWMValues(dmxValue, dmxValue, dmxValue); // Example: send same PWM values to both devices
  // Minus button
  // Plus button
  Serial.print('\t');
  Serial.print('\t');
  Serial.flush();
sadly no serial bc with the dmx library apparently that won't work and gives me a compiling error. (had that earlier and took some time to find out why)
i'll try it without that
you send only one value for one channel, right?
so, you must send on three channels for each PWM, right?
you can put discrete LED in Uno board to same 3,5,6 pins and see on it what value is corresponding
it should send the value of the 1st dmx channel (the dmx start address) to PWM pin 1, the one from the second (dmx start address +1) to the second pwm pin and the third is dmx start adress +2
