Hi everyone, I'm new using the arduino products so that's why I need your help. I have a proyect where I have to measure the AC voltage from transmissions lines with an arduino UNO and I don't know how to start. Can someone give me any guide from a code?
Transmission lines ? What is the maximum voltage you expect to measure ?
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Please READ THIS POST to help you get the best out of the forum.
Bob.
cindynunezr:
Google search for "stealing power from transmission lines" and you will find a whole bunch of ways to remotely access the transmission line voltage. Then use a full wave rectifier and measure the resulting DC voltage.
The real hard problem in your project is calibration.
Paul
This kind of questions are kinda scary. Normally anyone even getting near a power transmission line should be a certified electrician working for the power company that owns the transmission line. That kind of people should also know how to safely measure the voltage of such a line, and have access to the equipment to do just that.
Unless OP simply uses the wrong terms, and is thinking of household mains power, which is readily measured with commonly available voltage sensor modules.
Do it like the big boys use a transformer to translate to a voltage you can use, then you need to rectify it, filter it then read with the A/D and then do you math and conversion. Try this link: http://www.ti.com/lit/an/snoa682/snoa682.pdf
This response is to help you get started in solving your problem, not solve it for you.
Good Luck & Have Fun!
Gil
