Project: One Accelerometer and One MicroSD card
Hello,
I want to create a device that uses 3.3 Volts to collect accelerometer data and save the data on a microSD card.
The parts i will be using:
Accelerometer - ADXL362 [SPI]
microSD card adapter - Catalex MicroSD Card Adapter [SPI]
Based on this i will need a microcontroller that has two SPI.
Is there an microcontroller that can make this work that does not use many pins?
Also i am open for suggestions.
hi
you dont need 2 spi busses.
you can connect more deviced on the same bus they only need a seperate SS (slave select) line.
look at wiki Link
Oh cool, that something i did not think about.
I will definitely look into that, thanks for the suggestion!
