Project photo cabin
Hello, I am a new member. I am close to putting together a project that would be quite easy for someone with a little more experience than I.
I am using some code I found on the examples to determine the amount inserted into my coin collector, but I am at a loss when it comes to shooting a picture. Thats all I need. I have the camera tethered to the computer, I thought I could use eos utility to shoot the photo, but have no idea on how to do it.
Maybe this can be achieved using a hd webcam, and triggering it through a keystroke comand. For example I have a tiny webcam software that shoots when crtl+i is pressed. Maybe the arduino can send the key stroke when the right ammount is inserted.
Please include the command and the library needeD in your answer.
Below is the code I have so far:
const int coinInt = 0;
//Attach coinInt to Interrupt Pin 0 (Digital Pin 2). Pin 3 = Interrpt Pin 1.
volatile float coinsValue = 0.00;
//Set the coinsValue to a Volatile float
//Volatile as this variable changes any time the Interrupt is triggered
int coinsChange = 0;
//A Coin has been inserted flag
//Start Serial Communication
  attachInterrupt(coinInt, coinInserted, RISING);
//If coinInt goes HIGH (a Pulse), call the coinInserted function
//An attachInterrupt will always trigger, even if your using delays
void coinInserted()
//The function that is called every time it recieves a pulse
  coinsValue = coinsValue + 0.05;
//As we set the Pulse to represent 5p or 5c we add this to the coinsValue
  coinsChange = 1;
//Flag that there has been a coin inserted
  if(coinsChange == 1)
//Check if a coin has been Inserted
    coinsChange = 0;
//unflag that a coin has been inserted
   if(coinsValue >= 0.30)
WHEN THE COINS VALUE REACH .30 I NEED TO TAKE A PHOTO.
PLEASE HELP.
USING ARDUINO UNO
That is a very small extract of your code, surely? Nothing resets the coinValue so it will take picture continually. Use a int variable that counts cents, not a float that counts dollars/cents. Floats are not accurate. It usually is overkill to use interrupts, it causes all sort of subtle problems. loop() will run more than 500000 times a second with your code so it can see the coin going past.
But to get back to the original question - you want to trigger a camera from the arduino, where the camera picture goes to a pc.
Re-stating your problem, you want a signal sent from the Arduino to the pc. With the Uno you have two possibilities: (1) SoftwareSolution: you use the USB/Serial connection. You write a pc program, f.eks. using Processing from Processing.org which in turn does the camera communication. (2) HardwareSolution: You buy a USB-Host shield and the Arduino can be made to appear as a USB keyboard device. Or you buy a Leonardo instead as it can pretend it is a keyboard (I believe)
I have done several photo booth / photo cabin projects in the past. Most of the time I used eos utility to shoot the photos. And I wrote some software (for PC) to "push the button", display the photo on a monitors, send it to a printer or/and website. But this has nothing to do with Arduino. OK, sometimes there was a big illuminated (blinking) pushbutton involved, driven by an Arduino Leonardo that was connected to the laptop. But also this I would not describe as an Arduino project.
Of course you could use a Leonardo (or Micro). They can act as a USB keyboard (or mouse), to send space key to eos utiliy. This will take a picture. With the appropriate settings, eos utility will download the photo from the camera. With some additional software you could send it to a printer and so on...
(Almost) everything that can be done with a USB keyboard can also be done with Leonardo or Micro. You could work on command line or control some software (which is already there - so there is no need to program it yourself).
Msquare & uxomm :
Both of your answers are incredibly helpful. And I appreciate you taking the time to writing them. From what I get the USB-host shield is basically the end of my problems. Processing seems to me to be a bit on the challenging level. Though interesting, it is a different approach to one that I am comfortable with.
To expand on the idea, I am going to be using arduino to send the spacekey just as uxomm suggested. And as both pointed out, I need a usb-host shield, which is to be found on the Leonardo not the uno. =(.
Anyhow I was thinking on a different solution earlier today and would appreciate additional help on the matter. If I write a AHK .exe file that would launch eos utility and snap the image.
Is it possible to execute it from the arduino code?
Msquare: That is a very small extract of your code, surely? Nothing resets the coinValue so it will take picture continually. Use a int variable that counts cents, not a float that counts dollars/cents. Floats are not accurate. It usually is overkill to use interrupts, it causes all sort of subtle problems. loop() will run more than 500000 times a second with your code so it can see the coin going past.
I appreciate the effort to point me in the right direction. I understand the need to reset coinValue. But the fact that I had not picked on it earlier just points to my inexperience in this situation. Would you write a similar code that would execute a file called "time_to_shoot"? I would greatly appreciate it. I will then have no need to buy additional hardware or inmerse in learning material at processing.org.
Greatly appreciate your help.
No.
After the Arduino has sensed your coins and decided it is all valid and good, it can take action:
  • Send 5V signals on its various output pins. This could activate a relay/motor. Using this to "click" the camera has been suggested
  • Send some bytes on a serial interface, which typically is connected via the USB to the pc, or perhaps some other device.
  • With a USB Host shield or WiFi shield or Bluethooth shield or Net shield send some text via the choosen shield. It can not run an exe file.
