I'm not very familiar with power supplies but need to design one that fits my projects needs. I need it to supply three different voltages, 5v, 12v, and 24v. It also needs to have a "backup" battery so it go mobile at any moment. I need at least an amp for each, just to be safe. Any ideas?
Oh, one more question, should I isolate the power supply for each device even though they run on the same voltage?
buck conversion from 24 to 12 or 5 is easy and cheap with LM2596 modules, which would
suggest a 24V system voltage - however that may impact battery cost. If any of the loads
are motors you will need to consider stall currents - most power supplies will shutdown on
current overload, which doesn't work with motors.
