PROJECT QUESTION - Need help with LCD with Arduino
Hello!
I am having trouble with a project I am working on with an LCD display with an arduino.
This is my project thus far, and I am trying to get the LCD to update on button press. But, whenever I press the button nothing happens.
Here's my code:
#include <LiquidCrystal.h>
#define pass (void)0
using namespace std;
const int buttonPin = 10;
int buttonState = 0;
int lastButtonState = 0;
int buttonPushCount = 0;
bool bPress = false;
int value = 10;
int numPoints = 0;
String points;
String basePoints;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
 lcd.begin(16, 2);
 basePoints = "0000";
 points = basePoints;
 pinMode(buttonPin, INPUT_PULLUP);
  lcd.setCursor(0,0);
  lcd.print("  POINTS");
  lcd.setCursor(2,1);
  lcd.print(points);
  checkButton();
  if(bPress)
    bPress = false;
    lcd.clear();
    lcd.setCursor(0, 0);
    lcd.print("SCORE!");
    lcd.setCursor(2, 1);
    lcd.print("+100");
    pass;
void checkButton()
  buttonState = digitalRead(buttonPin);
  if(buttonState != lastButtonState)
    if(buttonState == LOW)
      bPress = true;
  buttonState = lastButtonState;
I am unsure as to what the problem is.
Thank you for reading and your help!
You have this the wrong way round. Try:
lastButtonState = buttonState;
What does this bit of code do:
The pinMode() of your button pin is set to INPUT_PULLUP which means that you need to arrange the circuit to take the button pin LOW when the button is pressed
Is that the way that your circuit is wired ? What is the resistor connected to the button doing there ?
Please check your button's connection.
The resistor is to connect the button to ground. Is this wrong?
Okay, thank you!
That pass keyword is (void)0 (line 3), but I could have implemented it wrong
It's supposed to just skip right through the else statement, "pass" it
It is not needed when using INPUT_PULLUP. Just take the pin LOW when the button is pressed and detect the change of state and the current LOW state to determine that the button has become pressed
Okay! It is working! Here's my code:
#include <LiquidCrystal.h>5
int value = 10;
int numPoints = 0;
String points;
String basePoints;
 lcd.begin(16, 2);
  lcd.setCursor(0,0);
  lcd.print("  ULTIMATE");
  lcd.setCursor(2,1);
  lcd.print("PINBALL");
  lcd.clear();
  lcd.print("POINTS:");
  lcd.print(points);
  checkButton();
  if(bPress)
    bPress = false;
    lcd.clear();
    lcd.print("+100");
    lcd.clear();
void checkButton()
    bPress = true;
      bPress = true;
Here's the circuit:
I just need to make the point value update
Thank you all for your help, I really appreciate it!
God bless!
Here's the code with point update:
int value = 10;
int numPoints = 0;
String points;
String basePoints;
 lcd.begin(16, 2);
 int basePoints = 0000;
 numPoints = basePoints;
  lcd.setCursor(0,0);
  lcd.setCursor(2,1);
  lcd.clear();
  lcd.print(numPoints);
  checkButton();
  if(bPress)
    bPress = false;
    lcd.clear();
    lcd.print("+100");
    numPoints = numPoints + 100;
    lcd.clear();
void checkButton()
    bPress = true;
      bPress = true;
