KatBME:
so in this case, the wire that would normally connect the switch the power is connected to the ground? Or am I miss understanding this?
I am a little concerned that you may be thinking of wiring in such a way as to cause a short circuit. With INPUT_PULLUP the power connection is inside the Arduino and the switch is connected so that when pressed it connects the pin to ground.
...R
