project: Sending SMS using SIM5320E, coding issue
This is the code I’m using and its taken from this website. I know its used for SIM900A so I changed the AT command according to this AT Commands Set.Though I might have made some errors because I’m still unable to successfully send a message to myself.
/*THIS TUTORIAL USED GSM SIM900A MINI V3.9.2
  Connect 5VT to D9 and 5VR to D10
  Feed GSM SIM900A with Arduino's 5V
  Code by IDAYU SABRI - MYBOTIC
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11);
char msg;
char call;
  mySerial.begin(9600);   // Setting the baud rate of GSM Module
  Serial.begin(9600);    // Setting the baud rate of Serial Monitor (Arduino)
  Serial.println("GSM SIM900A BEGIN");
  Serial.println("Enter character for control option:");
  Serial.println("h : to disconnect a call");
  Serial.println("i : to receive a call");
  Serial.println("s : to send message");
  Serial.println("c : to make a call");
  Serial.println("e : to redial");
  delay(100);
  if (Serial.available()>0)
   switch(Serial.read())
    case 's':
      SendMessage();
    case 'c':
      MakeCall();
    case 'h':
      HangupCall();
    case 'e':
      RedialCall();
    case 'i':
      ReceiveCall();
 if (mySerial.available()>0)
 Serial.write(mySerial.read());
void SendMessage()
  mySerial.println("AT+CSMP");    //Sets the GSM Module in Text Mode
  delay(1000);  // Delay of 1000 milli seconds or 1 second
  mySerial.println("AT+CMGS=\"+60XXXXXXXXXX\"\r"); // Replace x with mobile number
  mySerial.println("sim900a sms");// The SMS text you want to send
  delay(100);
   mySerial.println((char)26);// ASCII code of CTRL+Z
void ReceiveMessage()
  mySerial.println("AT+CNMI=2,2,0,0,0"); // AT Command to recieve a live SMS
    msg=mySerial.read();
    Serial.print(msg);
void MakeCall()
  mySerial.println("ATD+60XXXXXXXXXX;"); // ATDxxxxxxxxxx; -- watch out here for semicolon at the end!!
  Serial.println("Calling  "); // print response over serial port
void HangupCall()
  mySerial.println("ATH");
  Serial.println("Hangup Call");
void ReceiveCall()
  mySerial.println("ATA");
    call=mySerial.read();
    Serial.print(call);
void RedialCall()
  mySerial.println("ATDL");
  Serial.println("Redialing");
I did enter my phone number in the parts required but I removed it in when posting the code.
It might be a good idea to print the responses of the SIM532 to the Serial Monitor.
ok, but are there any issues with the code that is preventing this project from working?
ok I tried to use the SMS example from the examples they have included, but when I run it, the serial monitor never gives me the “ready” signal. Does this mean that there are issues connecting to the mobile network? How do I know if my device is connected to the mobile network?
the example code:
 SMS sender
 This sketch, for the Arduino GSM shield,sends an SMS message
 you enter in the serial monitor. Connect your Arduino with the
 GSM shield and SIM card, open the serial monitor, and wait for
 the "READY" message to appear in the monitor. Next, type a
 message to send and press "return". Make sure the serial
 monitor is set to send a newline when you press return.
 Circuit:
 * GSM shield
 * SIM card that can send SMS
 created 25 Feb 2012
 by Tom Igoe
 This example is in the public domain.
 http://www.arduino.cc/en/Tutorial/GSMExamplesSendSMS
// Include the GSM library
#include <GSM.h>
#define PINNUMBER ""
// initialize the library instance
GSM gsmAccess;
GSM_SMS sms;
  // initialize serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.println("SMS Messages Sender");
  // connection state
  boolean notConnected = true;
  // Start GSM shield
  // If your SIM has PIN, pass it as a parameter of begin() in quotes
  while (notConnected) {
    if (gsmAccess.begin(PINNUMBER) == GSM_READY) {
      notConnected = false;
      Serial.println("Not connected");
  Serial.println("GSM initialized");
  Serial.print("Enter a mobile number: ");
  char remoteNum[20];  // telephone number to send sms
  readSerial(remoteNum);
  Serial.println(remoteNum);
  // sms text
  Serial.print("Now, enter SMS content: ");
  char txtMsg[200];
  readSerial(txtMsg);
  Serial.println("SENDING");
  Serial.println("Message:");
  Serial.println(txtMsg);
The PINNUMBER definition is empty, so your SIM card is not activated. Might be part of the problem.
