I'm so confused now. I make a lite code with TimerOne and OneWire as I'm using it (see bellow) for try to compile it in 1.6.5 and in 1.8.3 version. And It's works without problem on both version.
So I remake old program as new project and just ctrl+c ctrl+v as parts by parts (function by function) ... and its works, I don't know how to, booth projects are same, but it's running.
I tried it at all version between 1.6.5 and 1.8.3 yesterday, and it works only on 1.6.5. Now is same code (in new creates project) works :D. Weird, but great.
Thank you everyone one more time.
Here is the test code:
#include <TimerOne.h> // http://playground.arduino.cc/Code/Timer1
#include <OneWire.h> // http://playground.arduino.cc/Learning/OneWire
#define Out1 3 // Digital 3
#define InDS1 4 // Digital 4
#define Out2 5 // Digital 5
#define Out3 6 // Digital 6
#define Out4 7 // Digital 7
// Digital 8
#define Out5 9 // Digital 9
#define Out6 10 // Digital 10
#define Out7 11 // Digital 11
#define Out8 12 // Digital 12
#define LED LED_BUILTIN // Digital 13
#define In8 A7 // Analog 7
#define In7 A6 // Analog 6
#define In6 A5 // Digital / Analog 5
#define In5 A4 // Digital / Analog 4
#define In4 A3 // Digital / Analog 3
#define In3 A2 // Digital / Analog 2
#define In2 A1 // Digital / Analog 1
#define In1 A0 // Digital / Analog 0
volatile byte dimCount = 0; // make volatile to make available in interrupt
const int freqStep = 86; // 1 / 86us / 64step = 182Hz
// Outputs
const byte range = 64; // Range
byte outDim[8] = {}; // Values
byte dimTimer = 0; // Timer for slowing
byte dimDelay = 100; // Slowing
// One Wire DS18B20
OneWire ds(InDS1);
byte dsCRC = 0; // CRC
int16_t dsValue[11] = {}; // Temperature RAW
byte dsSelect = 0; // Device select
const byte dsMax = 3; // No of devices
int dsBlock = 2000; // Delay for init start
const int dsWaitC = 1000; // Delay for convert (ms)
const int dsWaitN = 50; // Delay for next devices (ms)
const int dsWaitR = 5000; // Delay for next round (ms)
byte dsAddress[11][8] ={
{0x28,0x25,0x9D,0xDB,0x06,0x00,0x00,0x5C}, // 0
{0x28,0x25,0x9D,0xDB,0x06,0x00,0x00,0x5C}, // 1
{0x28,0x4D,0x77,0xDB,0x06,0x00,0x00,0x59}, // 2
{0x28,0xA2,0xB6,0xDB,0x06,0x00,0x00,0xBB}, // 3
{0x28,0xC5,0xD0,0x36,0x06,0x00,0x00,0xA4}, // 4
{0x28,0xE2,0xB8,0xE6,0x05,0x00,0x00,0x5D}, // 5
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00}, // 6
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00}, // 7
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00}, // 8
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00}, // 9
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00} }; // 10
// Setup
void setup ()
// Outputs
pinMode (LED, OUTPUT);
pinMode (Out1, OUTPUT);
pinMode (Out2, OUTPUT);
pinMode (Out3, OUTPUT);
pinMode (Out4, OUTPUT);
pinMode (Out5, OUTPUT);
pinMode (Out6, OUTPUT);
pinMode (Out7, OUTPUT);
pinMode (Out8, OUTPUT);
// Inputs
pinMode (In1, INPUT);
pinMode (In2, INPUT);
pinMode (In3, INPUT);
pinMode (In4, INPUT);
pinMode (In5, INPUT);
pinMode (In6, INPUT);
pinMode (In7, INPUT); // A6 just analog
pinMode (In8, INPUT); // A7 just analog
// Timer
Timer1.initialize(freqStep);
Timer1.attachInterrupt(dimCheck, freqStep);
Timer1.disablePwm(9);
Timer1.disablePwm(10);
interrupts();
// Dimer
void dimCheck()
dimCount--;
if (dimCount < 1)
dimCount = range;
if (outDim[0] < range) {digitalWrite (Out1, LOW);}
if (outDim[1] < range) {digitalWrite (Out2, LOW);}
if (outDim[2] < range) {digitalWrite (Out3, LOW);}
if (outDim[3] < range) {digitalWrite (Out5, LOW);}
if (outDim[4] < range) {digitalWrite (Out6, LOW);}
if (outDim[5] < range) {digitalWrite (Out7, LOW);}
if (outDim[0] > dimCount) {digitalWrite (Out1, HIGH);}
if (outDim[1] > dimCount) {digitalWrite (Out2, HIGH);}
if (outDim[2] > dimCount) {digitalWrite (Out3, HIGH);}
if (outDim[3] > dimCount) {digitalWrite (Out5, HIGH);}
if (outDim[4] > dimCount) {digitalWrite (Out6, HIGH);}
if (outDim[5] > dimCount) {digitalWrite (Out7, HIGH);}
// OneWire - Handle Event
void OneWireEvent ()
dsBlock--;
if (dsBlock <= 1) // Its time to handle
digitalWrite (LED, LOW); // Show OneWire aktivity
dsBlock = 1;
if (dsSelect <= 0) // Convert
OW_Convert ();
dsBlock = dsWaitC; // Delay for convert
dsSelect = 1; // Next step
digitalWrite (LED, HIGH); // Show OneWire aktivity
else if (dsSelect <= dsMax) // Step X (reading)
OW_Read (dsSelect - 1); // Read
dsBlock = dsWaitN; // Delay for next device
dsSelect++;
else // All device done
dsBlock = dsWaitR; // Delay for next event
dsSelect = 0; // Next event is convert
// OneWire - Convert
void OW_Convert ()
if (ds.reset ())
ds.write (0xCC); // Skip ROM
ds.write (0x44); // Convert
// OneWire - Read
void OW_Read (byte num)
byte owTry = 3; // How many times try to read data
byte owVal = 0; // Tempoary value
byte owL = 0; // Low byte
byte owH = 0; // High byte
while (owTry) // Try to read
dsCRC = 0;
if (ds.reset ()) // Reset
ds.select (dsAddress [num]); // Address
ds.write (0xBE); // Request
for (byte oo = 0; oo < 8; oo++) // Reading 8 byte
owVal = ds.read (); // 1 byte
owCRC (owVal); // CRC
if (oo == 0) {owL = owVal;} // Ulozeni teplot
if (oo == 1) {owH = owVal;}
owVal = ds.read (); // Reading CRC
if (owVal == dsCRC) // Check CRC
dsValue[num] = (owH << 8) | owL; // Save data
owTry = 0; // OK, finish
owTry--; // CRC Error, repeating
else {owTry = 0;} // Do device > end
// OneWire - CRC
void owCRC (byte data)
byte oCRC_loop = 0;
byte oCRC_tmp = 0;
for (oCRC_loop = 8; oCRC_loop != 0; oCRC_loop--)
oCRC_tmp = (data ^ dsCRC) & 1;
data >>= 1;
dsCRC >>= 1;
if (oCRC_tmp != 0)
dsCRC ^= 0x8C;
// MAIN LOOP
void loop ()
OneWireEvent (); // DS Reading
// Diming
dimTimer++;
if (dimTimer >= dimDelay)
byte rr = random (0, 6);
byte rw = random (0, range);
outDim[rr] = rw;
dimTimer = 0;
delay (1);
