I have several questions on how the Arduino works to implement a project.
I need to control outputs, with commands coming through the ethernet or input pin at the same time.
Without multi threading in arduino is possible?
or
is easy to implement multi threading in arduino for the tasks mentioned above?
Pressure switch as input works fine in Arduino or give boucing problem?
If the aim is to read the various inputs binary (5V or 0V), can have multiple inputs connected to GND smoothly to the arduino?
Yes, within the context of non-instantaneously; multiple instructions would be required and each instruction is in the order 4uS per instruction.
There is no (true) multi threading; the concept is foreign to Arduino.
or
No, you could however implement a lightweight kernel that would provide semaphores and scheduling: Google: RTOS+Arduino.
You will need to implement external hardware or software debouncing.
The input pins can swing between 0 (ground) and no higher than 5?5V if the uC is driven by 5.0V.
Such questions obviously are answered in the related Atmel uC data sheet.
I am not familar with the ethernet stuff for Arduinos but, in general WHILE loops are blocking and should be avoided if blocking is a problem. I presume you can check if there is a character available and read it without needing blocking code.
The simple solution to pseudo parallel actions on the Arduino is the technique used in the Blink Without Delay example sketch. I wrote an extended demo of it in the first post in this Thread.
You can download and explore the Arduino IDE without needing an Arduino board - though of course you can't run any programs (sketches).
Is there a client.available() function that is equivalent to Serial.available() which tells you how many characters are waiting in the Serial input buffer?
