Project using a potentiometer
For a project I am trying to mimic the sun’s movement using 10 LEDs placed a long an arc and was wondering if it is possible to use a potentiometer that when adjusted would turn an LED on in sequence along that arc. So essentially the LED sequence would move left or right depending on the direction the user is adjusting the knob to mimic a user-controlled sun. If possible, what would be the best way to achieve this?
Pretty easy
void loop(){
int val = analogRead(potPin);
if (val <100){digitalWrite (2, HIGH);}
else }{digitalWrite (2, LOW);}
if (van >=100 && val < 200){ digitalWrite (3, HIGH);}
else {digitalWrite(3, LOW);}
etc for pins 4-11 and additional ranges
Define variables, add pinMode to setup(), etc.
