Project using MPU 92-50 accelerometer and arduino uno
I'm trying to make a crash detection algorithm using the mpu 92-50 accelerometer and arduino, but when trying to acces data using the following code:
#include <Wire.h>
#include <MPU9250.h>
MPU9250 imu(Wire, MPU9250_ADDRESS_AD0);
Wire.begin();
imu.setAccelRange(MPU9250::ACCEL_RANGE_2G);
imu.setGyroRange(MPU9250::GYRO_RANGE_250DPS);
imu.begin();
imu.readSensor();
float ax = imu.getAccelX_mss();
float ay = imu.getAccelY_mss();
float az = imu.getAccelZ_mss();
Serial.print("Acceleration (m/s^2): ");
Serial.print(ax);
Serial.print(", ");
Serial.print(ay);
Serial.print(", ");
Serial.println(az);
delay(100);
I get the following error :
In file included from C:\Users\Serju\AppData\Local\Temp.arduinoIDE-unsaved2023227-3308-12bjud4.ee0a\sketch_mar27a\sketch_mar27a.ino:1:0:
C:\Users\Serju\Documents\Arduino\libraries\Bolder_Flight_Systems_MPU9250\src/mpu9250.h:36:10: fatal error: cstddef: No such file or directory
#include
compilation terminated.
exit status 1
Compilation error: exit status 1
I can't quite figure out why, any help would be great.
After installing a library, always test the installation by running one of the library examples.
With a sensor library, make sure that you have wired the senso, as required by the library.
I tried running the library examples and i get the same error. The sensor is wired as required but this is an error when i verify the code
Sniffing through Google answers to "cstddef" I ended up on this GitHub topic that has an answer from a Forum member that I see sometimes here (@oqibidipo). Maybe he/she can get a light over the problem.
Maybe the library you´re using is deprecated?
If you need only acceleration values, then a device library is not required (other than the built in Wire library). This example code works with either the MPU-6050 or the MPU-9250 to read acceleration values and compute tilt angles.
You may need to change the I2C address.
// minimal MPU-6050 tilt and roll (sjr). Works with MPU-9250 too.
// works perfectly with GY-521, pitch and roll signs agree with arrows on sensor module 7/2019
// Tested with 3.3V eBay Pro Mini with no external pullups on I2C bus (worked with internal pullups)
// Add 4.7K pullup resistors to 3.3V if required. A4 = SDA, A5 = SCL
#include<Wire.h>
const int MPU_addr1 = 0x68;
float xa, ya, za, roll, pitch;
  Wire.begin();                                      //begin the wire communication
  Wire.beginTransmission(MPU_addr1);                 //begin, send the slave adress (in this case 68)
  Wire.write(0x6B);                                  //make the reset (place a 0 into the 6B register)
  Wire.write(0);
  Wire.endTransmission(true);                        //end the transmission
  Wire.write(0x3B);  //send starting register address, accelerometer high byte
  Wire.endTransmission(false); //restart for read
  Wire.requestFrom(MPU_addr1, 6); //get six bytes accelerometer data
  int t = Wire.read();
  xa = (t << 8) | Wire.read();
  t = Wire.read();
  ya = (t << 8) | Wire.read();
  t = Wire.read();
  za = (t << 8) | Wire.read();
// formula from https://wiki.dfrobot.com/How_to_Use_a_Three-Axis_Accelerometer_for_Tilt_Sensing
  roll = atan2(ya , za) * 180.0 / PI;
  pitch = atan2(-xa , sqrt(ya * ya + za * za)) * 180.0 / PI; //account for roll already applied
  Serial.print("roll = ");
  Serial.print(roll,1);
  Serial.print(", pitch = ");
  Serial.println(pitch,1);
  delay(400);
