I'm building a project to automatically, based on light levels, open/close a chicken coup door. All going well so far, Using an Arduino Uno and a Motor shield I now have a working program. I wanted to move to the next stage of incorporating an ethernet shield to put put status changes outputs to twitter however there seems to be a clash of pins between the motor shield and the ethernet shield. Is that correct? Are there ways around it?
scot101:
the motor shield and the ethernet shield.Are there ways around it?
I suppose that would depend which motor shield and which ethernet shield you were using.
If the ones you have clash pins, it's possible to fit an inbetween shield to reroute the pins - or do this yourself by wiring the connection to the shield instead of plugging it in directly.
