Project with unidirecional communication between 2 Arduinos
Hello everybody I am new in the group and with little knowledge of Arduino. I’m trying to make a project about unidirectional communication between two Arduino ( one Tx and one Rx) , the Tx Arduino sends the “Hello World” and the Rx Arduino receives that sentence. For that I have to use IR communication ( Transmitting IR LED and receiving IR photo sensor) and to avoid errors or loss of data communication I will have to implement some kind of error detecting and error correction (maybe interleaving FEC?), could you give me some tips for an easy way to do this?
I send my small and simple code, I can already send and receive the sentence.
Thanks in advance!!
Transmitter.ino
#include <SoftwareSerial.h>
#define rxPin 3
#define txPin 4
SoftwareSerial XSERIAL = SoftwareSerial(rxPin, txPin);
XSERIAL.begin(9600);
XSERIAL.println(“Hello World”);
delay(10);
Receiver.ino
#define rxPin 2
#define txPin 3
SoftwareSerial XSERIAL = SoftwareSerial(rxPin, txPin, false);
Serial.println(“Start Listening…”);
if (XSERIAL.available())
incomingByte = (char)XSERIAL.read()
Serial.print("I received: ");
Serial.println(incomingByte);
Maybe send a checksum and reject the message if it is wrong at the receiving end.
Not so easy, but a Google search should turn something up, including algorithms, which you can incorporate into the code.
Have a look at the third example in Serial Input Basics. Surrounding your data with start- and end-markers may give sufficient reliability. You could also include a byte which denotes the length of the message as an additional simple check.
It is also easy to use XOR to create a single check digit - XOR all the bytes in the message and include the result as an additional byte.
I know nothing about error correction. Is it really necessary?
I assume you are sending the data with a "proper" IR carrier frequency (38kHz?). If not you may be interested in this Thread.
...R
Thanks a lot guys, I already send and receive "well"... now I'm trying to implement the Error correction but it's tough , if checksum fails I'm trying to print the message as the receiver receives the message or wait for the next message and compare...
It would be simpler if your message had a marker for the beginning of the message.
