Project works on Arduino Uno but doesn't work on Arduino Pro Mini ATMega 328P (XCSource)
I'm currently building drinking game using Arduino. Everything works as intended on the Uno, but now i soldered everything on the Pro Mini and now it keeps resetting. In the setup function I send a HIGH signal to pin 9, 10 and 12 for 4 sec, one after another. By doing this I activate the relays, which leads to the pumps going on. The first time I ran the programm on the pro mini, the first pump pumped for 4 sec as intended, but when it turned on the second pump, the arduino reset and it was stuck in a loop doing resets every few seconds. After that, I put 2 capacitors between the VCC and the GRD pin, which fixed the problem. Next I pressed the button to send a HIGH signal to pin 13, but then the arduino reset again and it was stuck in a reset loop again. How do I deal with this problem, it probably has something to do with the voltage regulator on the pro mini. Do I need more capacitors and if yes, where do i have to put them.
Thx in advance.
Fabian
PS. Sry for the bad schematic, I used a color code for some pins because it would be to hard to connect them by lines
PPS. The Code is german but I hope u get the gist of it
PPPS. I'm not allowed to upload the PDF of my Schematic because I'm a new user. I don't know if the Screenshot I took helps at all
The Code:
include <arduino-timer.h>
//pitch.h
#define NOTE_B0  31
#define NOTE_C1  33
#define NOTE_CS1 35
#define NOTE_D1  37
#define NOTE_DS1 39
#define NOTE_E1  41
#define NOTE_F1  44
#define NOTE_FS1 46
#define NOTE_G1  49
#define NOTE_GS1 52
#define NOTE_A1  55
#define NOTE_AS1 58
#define NOTE_B1  62
#define NOTE_C2  65
#define NOTE_CS2 69
#define NOTE_D2  73
#define NOTE_DS2 78
#define NOTE_E2  82
#define NOTE_F2  87
#define NOTE_FS2 93
#define NOTE_G2  98
#define NOTE_GS2 104
#define NOTE_A2  110
#define NOTE_AS2 117
#define NOTE_B2  123
#define NOTE_C3  131
#define NOTE_CS3 139
#define NOTE_D3  147
#define NOTE_DS3 156
#define NOTE_E3  165
#define NOTE_F3  175
#define NOTE_FS3 185
#define NOTE_G3  196
#define NOTE_GS3 208
#define NOTE_A3  220
#define NOTE_AS3 233
#define NOTE_B3  247
#define NOTE_C4  262
#define NOTE_CS4 277
#define NOTE_D4  294
#define NOTE_DS4 311
#define NOTE_E4  330
#define NOTE_F4  349
#define NOTE_FS4 370
#define NOTE_G4  392
#define NOTE_GS4 415
#define NOTE_A4  440
#define NOTE_AS4 466
#define NOTE_B4  494
#define NOTE_C5  523
#define NOTE_CS5 554
#define NOTE_D5  587
#define NOTE_DS5 622
#define NOTE_E5  659
#define NOTE_F5  698
#define NOTE_FS5 740
#define NOTE_G5  784
#define NOTE_GS5 831
#define NOTE_A5  880
#define NOTE_AS5 932
#define NOTE_B5  988
#define NOTE_C6  1047
#define NOTE_CS6 1109
#define NOTE_D6  1175
#define NOTE_DS6 1245
#define NOTE_E6  1319
#define NOTE_F6  1397
#define NOTE_FS6 1480
#define NOTE_G6  1568
#define NOTE_GS6 1661
#define NOTE_A6  1760
#define NOTE_AS6 1865
#define NOTE_B6  1976
#define NOTE_C7  2093
#define NOTE_CS7 2217
#define NOTE_D7  2349
#define NOTE_DS7 2489
#define NOTE_E7  2637
#define NOTE_F7  2794
#define NOTE_FS7 2960
#define NOTE_G7  3136
#define NOTE_GS7 3322
#define NOTE_A7  3520
#define NOTE_AS7 3729
#define NOTE_B7  3951
#define NOTE_C8  4186
#define NOTE_CS8 4435
#define NOTE_D8  4699
#define NOTE_DS8 4978
//pitch.h end
//Pins
int A0_Pin = A0;
int A1_Pin = A1;
int A2_Pin = A2;
int A3_Pin = A3;
int A4_Pin = A4;
int Rdy_LED = 2;
int Stp_LED = 3;
int Prost_LED = 4;
int Berenzen_LED = 5;
int Jaeger_LED = 6;
int Tequila_LED = 7;
int Ex_LED = 8;
int Berenzen_Pump = 9;
int Jaeger_Pump = 10;
int Tequila_Pump = 12;
int buzzer = 11;
int Knopf = 13;
//Variablen
int Status = 0;
int LEDBlock = 0;
int lux_Grenze = 200;
int A0_Start;
int A1_Start;
int A2_Start;
int A3_Start;
int A4_Start;
int Berenzen_Time=0;
int Jaeger_Time=0;
int Tequila_Time=0;
long Dauer;
long TimerStart;
int Noten[]={NOTE_A5, NOTE_G6};
int Noteni = 0;
int blinken = 0;
//LED Blink
int P_LED_i = 0;
int B_LED_i = 0;
int J_LED_i = 0;
int T_LED_i = 0;
int E_LED_i = 0;
auto timer_LED = timer_create_default();
auto timer_Pump = timer_create_default();
///////////////////////////////LED Blink//////////////////////////////////
bool toggle_P_LED(void *) {
  digitalWrite(Prost_LED, !digitalRead(Prost_LED));
  if(P_LED_i >=10)
    digitalWrite(Prost_LED, LOW);
    StartLuxSetzen();
    Status = 0;
    LEDBlock = 0;
    digitalWrite(Rdy_LED, HIGH);
    digitalWrite(Stp_LED, LOW);
    P_LED_i = 0;
    return false;
  P_LED_i++;
  return true;
bool toggle_B_LED(void *) {
  digitalWrite(Berenzen_LED, !digitalRead(Berenzen_LED));
  if(Status == 0)
    digitalWrite(Berenzen_LED, LOW);
    B_LED_i = 0;
    LEDBlock = 0;
    return false;
  B_LED_i++;
  return true;
bool toggle_J_LED(void *) {
  digitalWrite(Jaeger_LED, !digitalRead(Jaeger_LED));
  if(Status == 0)
    digitalWrite(Jaeger_LED, LOW);
    J_LED_i = 0;
    LEDBlock = 0;
    return false;
  J_LED_i++;
  return true;
bool toggle_T_LED(void *) {
  digitalWrite(Tequila_LED, !digitalRead(Tequila_LED));
  if(Status == 0)
    digitalWrite(Tequila_LED, LOW);
    T_LED_i = 0;
    LEDBlock = 0;
    return false;
  T_LED_i++;
  return true;
bool toggle_E_LED(void *) {
  digitalWrite(Ex_LED, !digitalRead(Ex_LED));
  digitalWrite(Rdy_LED, !digitalRead(Rdy_LED));
  digitalWrite(Stp_LED, !digitalRead(Stp_LED));
  if(Noteni>=2)
    Noteni = 0;
  tone(buzzer, Noten[Noteni]);
  if(E_LED_i >=20)
    digitalWrite(Ex_LED, LOW);
    E_LED_i = 0;
    StartLuxSetzen();
    Status = 0;
    LEDBlock = 0;
    noTone(buzzer);
    return false;
  E_LED_i++;
  Noteni++;
  return true;
///////////////////////////////LED Blink END///////////////////////////////
///////////////////////////////Auffuellen//////////////////////////////////
bool toggle_B_Pump (void * )
   digitalWrite(Berenzen_Pump, LOW);
   StartLuxSetzen();
   Status = 0;
   return false;
bool toggle_J_Pump (void * )
   digitalWrite(Jaeger_Pump, LOW);
   StartLuxSetzen();
   Status = 0;
   return false;
bool toggle_T_Pump (void * )
   digitalWrite(Tequila_Pump, LOW);
   StartLuxSetzen();
   Status = 0;
   return false;
///////////////////////////////Auffuellen END//////////////////////////////
  pinMode(Rdy_LED, OUTPUT);
  pinMode(Stp_LED, OUTPUT);
  pinMode(Prost_LED, OUTPUT);
  pinMode(Berenzen_LED, OUTPUT);
  pinMode(Jaeger_LED, OUTPUT);
  pinMode(Tequila_LED, OUTPUT);
  pinMode(Ex_LED, OUTPUT);
  pinMode(Berenzen_Pump, OUTPUT);
  pinMode(Jaeger_Pump, OUTPUT);
  pinMode(Tequila_Pump, OUTPUT);
  pinMode(buzzer, OUTPUT);
  pinMode(Knopf, INPUT);
  A0_Start = analogRead(A0_Pin);
  A1_Start = analogRead(A1_Pin);
  A2_Start = analogRead(A2_Pin);
  A3_Start = analogRead(A3_Pin);
  A4_Start = analogRead(A4_Pin);
  digitalWrite(Stp_LED, HIGH);
  Status = 0;
  LEDBlock = 0;
  digitalWrite(Berenzen_Pump, HIGH);
  delay(4000);
  digitalWrite(Jaeger_Pump, HIGH);
  delay(4000);
  digitalWrite(Tequila_Pump, HIGH);
  delay(4000);
  digitalWrite(Berenzen_LED, HIGH);
  while(Berenzen_Time == 0)
    if(digitalRead(Knopf)==HIGH)
      TimerStart = millis();
      while(digitalRead(Knopf)==HIGH)
      Dauer = millis() - TimerStart;
      Berenzen_Time = Dauer;
  digitalWrite(Jaeger_LED, HIGH);
  while(Jaeger_Time == 0)
      Jaeger_Time = Dauer;
  digitalWrite(Tequila_LED, HIGH);
  while(Tequila_Time == 0)
      Tequila_Time = Dauer;
  timer_LED.tick();
  timer_Pump.tick();
  if(Status == 0)
    if(analogRead(A0_Pin)> (A0_Start + lux_Grenze))
      Status = 1;
    if(analogRead(A1_Pin)> (A1_Start + lux_Grenze))
      Status = 2;
    if(analogRead(A2_Pin)> (A2_Start + lux_Grenze))
      Status = 3;
    if(analogRead(A3_Pin)> (A3_Start + lux_Grenze))
      Status = 4;
    if(analogRead(A4_Pin)> (A4_Start + lux_Grenze))
      Status = 5;
  Execute(Status);
void StartLuxSetzen()
void Execute (int Strafe)
  switch(Strafe)
    case 1:
    if(LEDBlock == 0)
      digitalWrite(Rdy_LED, LOW);
      LEDBlock = 1;
      timer_LED.every(500, toggle_P_LED);
    case 2:
    if(LEDBlock == 0)
      LEDBlock = 1;
      timer_LED.every(500, toggle_B_LED);
    if(digitalRead(Knopf) == HIGH)
      timer_Pump.every(Berenzen_Time, toggle_B_Pump);
    case 3:
    if(LEDBlock == 0)
      LEDBlock = 1;
      timer_LED.every(500, toggle_J_LED);
      timer_Pump.every(Jaeger_Time, toggle_J_Pump);
    case 4:
    if(LEDBlock == 0)
      LEDBlock = 1;
      timer_LED.every(500, toggle_T_LED);
      timer_Pump.every(Tequila_Time, toggle_T_Pump);
    case 5:
    if(LEDBlock == 0)
      LEDBlock = 1;
      timer_LED.every(500, toggle_E_LED);
    default:
Welcome to the forum.
You should not apply 12V to Vin and expect the Arduino to provide much current (even lighting a few LEDs may be too much), as the light-duty on board voltage regulator will overheat. Also, motor and relay noise will introduce voltage spikes into the power supply that can actually destroy the Arduino.
Either use a separate power supply for the Arduino, or add a step down regulator to produce 5V, and apply that to the Arduino 5V pin.
Hi thx for your response, so do you mean, I should desolder RAW and GND , connect the 12V to a step down regulator, and than solder that output to VCC and GND?
Disconnect 12V from Raw and connect 12V to the regulator input. Connect regulator 5V output to the 5V pin.
Connect all the grounds.
