Project
Hi
I’m working on a car project . its 40cm by 20cm and runs on three energy sources, my problem is that i want to use a uno board with ultrasonic sensors for the steering of the car. once the car reaches a wall it moves away … so can you help me what type of uno board do i use , and what about the program ?
thanks…
You can use an Uno..
Google for the code. I think are around 152 different websites with the code you need.
A really good way of earning a fast-track forum banning is to post the same question five or six times across the forum.
DO NOT CROSS-POST, IT WASTES TIME.
// This demo code checks the state of two switches
// and moves the stepper motor either clockwise or anticlockwise
// This code may be freely used and copied.
// Gareth Davies - June 2012
//declare variables for the motor pins
int motorPin1 = 8; // Blue - 28BYJ48 pin 1
int motorPin2 = 9; // Pink - 28BYJ48 pin 2
int motorPin3 = 10; // Yellow - 28BYJ48 pin 3
int motorPin4 = 11; // Orange - 28BYJ48 pin 4
// Red - 28BYJ48 pin 5 (VCC)
int cwpin = 2; // input pin for clockwise switch
int acwpin = 3; // input pin for anticlockwise switch
int motorSpeed = 1200; //variable to set stepper speed
int count = 0; // count of steps made
int countsperrev = 512; // number of steps per full revolution
int lookup[8] = {B01000, B01100, B00100, B00110, B00010, B00011, B00001, B01001};
//declare the motor pins as outputs
pinMode(motorPin1, OUTPUT);
pinMode(motorPin2, OUTPUT);
pinMode(motorPin3, OUTPUT);
pinMode(motorPin4, OUTPUT);
pinMode(cwpin, INPUT); // Active low switch input
pinMode(acwpin, INPUT); // Active low switch input
void loop(){
if (digitalRead(cwpin) == LOW)
clockwise();
else if (digitalRead(acwpin) == LOW)
anticlockwise();
/if(count < countsperrev )
clockwise();
else if (count == countsperrev * 2)
count = 0;
anticlockwise();
count++;
//set pins to ULN2003 high in sequence from 1 to 4
//delay “motorSpeed” between each pin setting (to determine speed)
void anticlockwise()
for(int i = 0; i < 8; i++)
setOutput(i);
delayMicroseconds(motorSpeed);
void clockwise()
for(int i = 7; i >= 0; i–)
setOutput(i);
void setOutput(int out)
digitalWrite(motorPin1, bitRead(lookup[out], 0));
digitalWrite(motorPin2, bitRead(lookup[out], 1));
digitalWrite(motorPin3, bitRead(lookup[out], 2));
digitalWrite(motorPin4, bitRead(lookup[out], 3));
i have found this code for the stepper motor, how can i change the input from two switches to two ultrasonic sensors ?
thanks in advance,
Do you have working code for the sensors? Once you have that, you can take out the switch part and insert the sensor code.
