Project
Hello I'm working on a project for school and I'm having a bit of road block.
I'm got the first part figured out. I'm having a problem with the heatbox aspect of this project. Any advice or direction where I could explain this better would be helpful.
· During initial board start-
o All LEDs flash 3 times within 2 seconds
· Normal Operations
o White LED 1 turns on in light conditions and off in dark conditions
o White LED 2 turns on in dark conditions and off in light conditions
o White LED 3 turns on with first button press and stays on until a second button press. –Tied to heating process described below
o LED 4 turns on and stays on the entire time the board is running except:
§ At 30 second intervals – LED 4 turns of and back on.
o Heating Box Maintains a temperature of 30-40 Celsius
§ When Heating Element is engaged – LED5 is on
§ Heating Box Control Modes –
· Open Loop Control Mode
o After First Button Press
§ LED 6 is on
§ Heating Element turns on for an estimated amount of time to up temp
§ Element Turns off After Duration
§ Fan Vents Chamber for 3 seconds
· Closed Loop Limit Cycle Control
o After Second Button Press
§ LED 6 and LED 7 Is On
§ Temp Sensor Monitors Temp in Hot Box
Heater Turns On/Off when appropriate
What is the problem with the box?
So post the code for the part that you have figured out and include your attempt to get the rest going and details of any problems.
Then if you want help you will also need to provide a lot more information about all the components you are using. Temperature sensor? Heat box? Light sensor? Power? A schematic would also help.
Steve
I recommend a state machine model. Here is an example you can use as a basis. Your sketch will have more states. For example, any part where a timer is running will be a separate state.
// Example Finite State Machine
// The pin 13 LED is blinking ON for 0.5s and OFF for 4.5s.
// Until a LOW on D6 triggers it to immediately go ON for 2s, and then return to the 5s cycling.
enum FSMStages {ENTERING, RUNNING, EXITING};
typedef void (FSMStateFunction)(FSMStages stage);
// A function for each state the FSM can be in
void BlinkOn(enum FSMStages stage);
void BlinkOff(enum FSMStages stage);
void ButtonPressed(enum FSMStages stage);
const unsigned long BLINK_ON_INTERVAL = 500;
const unsigned long BLINK_OFF_INTERVAL = 4500;
const unsigned long BUTTON_PRESSED_INTERVAL = 2000;
const byte Button_IPPin = 6;  // INPUT_PULLUP pin for the button
  pinMode(Button_IPPin, INPUT_PULLUP);
  pinMode(LED_BUILTIN, OUTPUT);
  // Starting in the BlinkOn state
  FSMEnterState(BlinkOn);
  FSMRun();
  static unsigned long startTime = 0;
  unsigned long currentTime = millis();
  switch (stage)
    case FSMStages::ENTERING:
      Serial.println("On");
      digitalWrite(LED_BUILTIN, HIGH); // ON
      startTime = currentTime;
    case FSMStages::RUNNING:
      // Is the interval over?
      if (currentTime - startTime >= BLINK_ON_INTERVAL)
        FSMChangeState(BlinkOff);
      // Has the button been pressed?
      if (digitalRead(Button_IPPin) == LOW)
        FSMChangeState(ButtonPressed);
    case FSMStages::EXITING:
  switch (stage)
      Serial.println("Off");
      digitalWrite(LED_BUILTIN, LOW); // OFF
      if (currentTime - startTime >= BLINK_OFF_INTERVAL)
        FSMChangeState(BlinkOn);
void ButtonPressed(FSMStages stage)
  switch (stage)
      Serial.println("Pressed");
      if (currentTime - startTime >= BUTTON_PRESSED_INTERVAL)
// Finite State Machine utility functions
void (*FSMCurrentState)(FSMStages stage);
void FSMRun()
  (*FSMCurrentState)(FSMStages::RUNNING);
// Enter a new state
void FSMEnterState(FSMStateFunction *SF)
  FSMCurrentState = SF;
  (*FSMCurrentState)(FSMStages::ENTERING);
// Exit current state
void FSMExitState()
  (*FSMCurrentState)(FSMStages::EXITING);
void FSMChangeState(FSMStateFunction *SF)
  FSMExitState();  // Exit current state
  FSMEnterState(SF);  // Enter a new state
Here is the code I have thus far
const int lightSensor= 5; //pin for light source
const int button = 10; //pin for button
int buttonState= 0; //state of the button
int LED1 = 8; //pin 1 for LED1
int LED2 = 2; //pin 2 for LED2
int LED3 = 3; //pin 2 for LED3
int LED4 = 4; //pin 4 for LED4
int LED5 = 5; //pin 5 for LED5
int LED6 = 6; //pin 6 for LED6
int LED7 = 7; //pin 7 for LED7
unsigned long previoustime=0; //setup time for flashing of LED4
int val =0; //set value for button
int old_val = 0; //set old value for button
int state = LOW; //set button off
int sensValue = 0; //variable to hold sensor readings
int buttonVal = 0; //variable to hold button read
 pinMode(LED1, OUTPUT); // Intiates pin as an output
 pinMode(LED2, OUTPUT); // Intiates pin as an output
 pinMode(LED3, OUTPUT); // Intiates pin as an output
 pinMode(LED4, OUTPUT); // Intiates pin as an output
 pinMode(LED5, OUTPUT); // Intiates pin as an output
 Serial.begin(9600); //begin serial communication
 lightsOn();
 delay(300);
 lightsOff();
 delay(300);
 lightsOn();
 delay(300);
 lightsOff();
 delay(300);
 lightsOn();
 delay(300);
 lightsOff();
void ledThirty(){
 digitalWrite(LED4, HIGH);  // Turn on LED4
 if (millis()- previoustime >=30000){   //set time to flash at 30 seconds
   digitalWrite(LED4, LOW);    //turn off LED1
   delay(300);  //delay for LED4
   digitalWrite(LED4, HIGH); // TURN ON LED
   previoustime = millis(); // used to reset previoustime to match millis
void SerialOutput(){
 Serial.print("Value");
 Serial.print(sensValue); //out sensor value to scren
 Serial.print("\n");
void lightsOn() {
 digitalWrite(LED1,HIGH); // Turn on LED1
 digitalWrite(LED2,HIGH); // Turn on LED2
 digitalWrite(LED3,HIGH); // Turn on LED3
 digitalWrite(LED4,HIGH); // Turn on LED4
 digitalWrite(LED5,HIGH); // Turn on LED5
 digitalWrite(LED6,HIGH); // Turn on LED6
 digitalWrite(LED7,HIGH); // Turn on LED7
void lightsOff(){
 digitalWrite(LED1,LOW); // Turn on LED1
 digitalWrite(LED2,LOW); // Turn on LED2
 digitalWrite(LED3, LOW); // Turn on LED3
 digitalWrite(LED4,LOW); // Turn on LED4
 digitalWrite(LED5,LOW); // Turn on LED5
 digitalWrite(LED6,LOW); // Turn on LED6
 digitalWrite(LED7,LOW); // Turn on LED7
void buttonPush(){
 val = digitalRead(button); //Read PIN position state
 if ((val ==1) &&(old_val ==0)){ //status of the button
 if(state == LOW){ //button off
   state =HIGH; //state of button is on
    else{ // else statement for if
     state = LOW; //button off
 old_val = val;  //set old_val to val
 if (state == LOW){  // if state is low
   digitalWrite(LED5, HIGH); //turn on LED4
     else {
       digitalWrite(LED5, LOW); //Turn off LED4
void lightRead(){ //for light sensor
 if (sensValue <= 300) { //if sensor value is below 500 switch on LED2
   digitalWrite(LED2, HIGH);
 else {  //if sensor value is above 500 turn on LED3
   digitalWrite(LED2, LOW);
   digitalWrite(LED3, HIGH);
 sensValue = analogRead(lightSensor); //read data from sensor
 ledThirty();
 lightRead();
 SerialOutput();
I haven't even started on temp sensor stuff yet.
Please edit your post to add code tags. See the "How to get the best out of the forum" post.
My apologies
I think it would be best to, as per #3, convert your operations to a state machine or, if using an ESP32 convert your code to using freeRTOS.
You still have not described the actual problems you have.
What is supposed to happen, and what happens instead?
My actual problem is writing the closed loop for the final step. I know I need an if statement that says if the temperature drops below the 40 Celsius that I have to turn on the heater and to turn on the fan if it goes over 60 celsius
If temp < 40 turn on heater
if temp > 60 turn on fan.
Here's a simple (i.e. non PID) concept for a "closed loop" heater control:
//change pin assignments as needed
const uint8_t LED6 = 8;
const uint8_t LED7 = 9;
const uint8_t pinBlower = 10;
const uint8_t pinHeaterRelay = 11;
enum statesHeater
    HEATER_INIT = 0,
    HEATER_OFF,
    HEATER_ON,
    HEATER_OVERHEAT
#define HEATER_CTL_INTERVAL     50ul        //mS    heater control interval
const float TARGET_TEMP = 35.0;             //oC    desired temperature
const float LOW_HYSTERESIS = 1.0;           //oC    low-side hysteresis (temp must fall below desired - low for heater on condition)
const float HIGH_HYSTERESIS = 1.0;          //oC    high-side hysteresis (temp must rise above desired + high for heater off condition)
const float OVERHEAT_THRESHOLD = 60.0;      //oC    overheat temperature at which fans come on and heater turned off
const float OVERHEAT_RECOVERY = 25.0;
void Heater_SM( void )
    static uint8_t
        stateHeater = statesHeater::HEATER_INIT;
    static uint32_t
        timeHeater;
    uint32_t
        timeNow = millis();
    if( (timeNow - timeHeater) < HEATER_CTL_INTERVAL )
        return;
    timeHeater = timeNow;
    float TempoC = GetHeaterTemperature();          //<--- return temp in oC
                                                    //could add filtering if temperature reading is noisy
    switch( stateHeater )
        case    statesHeater::HEATER_INIT:
            digitalWrite( LED7, HIGH );                         //init closed-loop indicator on
            digitalWrite( LED6, LOW );                          //init heater-on indicator off
            digitalWrite( pinHeaterRelay, LOW );                //init heater off
            //...add other inits as required
            stateHeater = statesHeater::HEATER_OFF;             //move to off state
        case    statesHeater::HEATER_OFF:
            //normal operation:
            //heater is off now; is temp cool enough to turn heater on?
            if( TempoC <= (TARGET_TEMP - LOW_HYSTERESIS) )
                digitalWrite( pinHeaterRelay, HIGH );           //turn heater on
                digitalWrite( LED6, HIGH );                     //heater-on indicator illuminated
                stateHeater = statesHeater::HEATER_ON;          //move to on state
            }//if
        case    statesHeater::HEATER_ON:
            //are we overheating?
            if( TempoC >= OVERHEAT_THRESHOLD )
                digitalWrite( pinHeaterRelay, LOW );            //turn off heater
                digitalWrite( LED6, LOW );                      //heater-on indicator off
                digitalWrite( pinBlower, HIGH );                //blower on
                stateHeater = statesHeater::HEATER_OVERHEAT;    //move to overheat state
            }//if
            else if( TempoC >= (TARGET_TEMP + HIGH_HYSTERESIS) )
                //normal operation:
                //heater is on now; is temp high enough to turn heater off?
            }//if
        case    statesHeater::HEATER_OVERHEAT:
            //overheat state
            //temperature must fall below OVERHEAT_RECOVERY temperature to re-enabled loop
            if( TempoC <= OVERHEAT_RECOVERY )
                //temperature is safe:
                digitalWrite( pinBlower, LOW );                 //blower off
                stateHeater = statesHeater::HEATER_OFF;         //go back to off state
            }//if
    }//switch
}//Heater_SM
float GetHeaterTemperature( void )
    float
        fTemp = 0.0;
    //whatever you do to read temperature
    return( fTemp );
}//GetHeaterTemperature
This is the code I'm coded in my Arduino sketch, I won't be able to test it till I get home. Not getting any errors when I check it, but I'm sure there will be some tweaking I need to do to it.
 * Final Lab
const int tempSensor = 4; //pin for temp sensor
const int Relay1 = 11; // pin for relay 1
const int Relay2 = 12; // pin for relay 2
const int LED1 = 8; //pin 1 for LED1
const int LED2 = 2; //pin 2 for LED2
const int LED3 = 3; //pin 2 for LED3
const int LED4 = 4; //pin 4 for LED4
const int LED5 = 5; //pin 5 for LED5
const int LED6 = 6; //pin 6 for LED6
const int LED7 = 7; //pin 7 for LED7
int buttonval=0; //value of button
int timer=0;  //timer value
const int state = LOW; //set button off
int countdownState=0; //count down state
float tval = 0; //Temp value
float tempcel = 0; // Tempature for celsuis
float diff = 24.03; // differencial
float tempsensValue = 0; // temp sensor reading
  pinMode(Relay1, OUTPUT); //relay 1 pin output
  pinMode(Relay2, OUTPUT); // relay 2 pin output
  lightsOn();
  delay(300);
  lightsOff();
  delay(300);
  lightsOn();
  delay(300);
  lightsOff();
  delay(300);
  lightsOn();
  delay(300);
  lightsOff();
void ledThirty(){
  Serial.print("Timer="); //provide text to explain output
  Serial.print(timer); //output variable x value
  Serial.print("\n"); // drop down a line
  Serial.print("buttonState="); //provide text to explain output
  Serial.print(buttonState); //output variable x value
  Serial.print("countdownState="); //provide text to explain output
  Serial.print(countdownState); //output variable x value
  Serial.print("\n"); // drop down a lineSerial.print("Value");
  Serial.print("\n");
  Serial.print("Temp Value");
  Serial.print(tempsensValue); //out sensor value to scren
  Serial.print("\n");
  Serial.print("Tval");
  Serial.print(tval); //out sensor value to scren
  Serial.print("\n");
  Serial.print("temcel=l");
  Serial.print(tempcel); //out sensor value to scren
  Serial.print("\n");
void lightsOn() {
 void lightsOff(){
  else {  //if sensor value is above 300 turn on LED3
void heater()
 if (tempcel >= 30) { //if tempcel is below 30 celsius turn on heater
    digitalWrite(Relay1,LOW);
    digitalWrite(Relay2,HIGH);
  else if(tempcel <=40) {
    digitalWrite(Relay1, HIGH);
    digitalWrite(Relay2,LOW);
void buttonCheck(){
  buttonval = digitalRead(button);  //check for button press
  if ((buttonval == 1) && (buttonState == 0))
    //if the button is pushed for the first time startup timer etc.
    digitalWrite(LED6, HIGH);
    digitalWrite(Relay1, LOW); //Turn on Heater
    delay(10000);
    digitalWrite(Relay1,HIGH);
    delay(3000);
    Serial.print("button pushed and state should change");
    Serial.print("\n");
    countdownState=1; //set variable to 1 to run countdown used in countdownCheck function
    buttonState=1; //increment buttonState by 1
  else if ((buttonval == 1) && (buttonState == 1)){
    // if the button is  pushed for the second time - reset everything and shutdown the counting function through countdownState=0
     digitalWrite(LED6, HIGH); //turn on
     digitalWrite(LED7,HIGH); //turn on
    countdownState = 0; //set variable to 1 to run countdown
    buttonState--; //decrement buttonState by 1
    timer=0; //reset the timer
    digitalWrite(LED3, LOW); //turn off LED
    digitalWrite(Relay1, HIGH); //turn on Relay1
   else if (tempcel >= 30) { //if tempcel is below 30 celsius turn on heater
   else if (tempcel <=40) {
void countdownCheck(){
  if ((countdownState == 1) && (timer != 30)) {
    //if the countdown is set to run (countdownState==1) and max time not met, turn on relay, led and increment the timer counter
    timer++; // increment timer
    digitalWrite(Relay1, LOW); //turn on relay
    digitalWrite(LED3, HIGH); //turn on LED
  if ((countdownState ==1) && (timer == 30)){
    //if we hit the maximum timer counter value of 5, reset countdownState to turn off counting and reset buttonState and timer
    countdownState = 0;//reset countdownState to off
    timer = 0; //reset the timer to 0
    buttonState = 0; //reset the buttonState for next cycle
    digitalWrite(Relay1, HIGH); //turn off relay
void tempRead(){
  tempsensValue = analogRead(tempSensor); //read sensor data
    tval = ((tempsensValue*3.3)/1024);
  tempcel= (tval * 100) - diff;sensValue = analogRead(lightSensor); //read data from sensor
  tempRead();
  buttonCheck();
  countdownCheck();ledThirty();
  lightRead();
  heater();
  SerialOutput();
 else if (tempcel >= 30)   //if tempcel is below 30 celsius turn on heater
The code does the opposite of what the comment says.
These two comments conflict.
The code would be easier to read if you use names like "HeaterRelay" and "FanRelay" rather than "Relay1" and "Relay2". For relay modules that use LOW to turn a relay ON and HIGH to turn a relay OFF it would be less confusing to the reader to define two constants to use with digitslWrite():
const int RelayOn = LOW;
const int RelayOff = HIGH;
Then you could use statements like:
    digitalWrite(HeaterRelay, RelayOn);
instead of:
John,
Thank you for catching that and thank you for the suggestions for the Relayon and off. I did change that to my code as it is much easier to read.
