Projekt mit WS2812b und NANO
Moin moin,
ich wollte auf diesem Weg mein aktuelles Projekt mit WS2812b und einem Nano vorstellen.
Pixelglas mit Ws2812b und Arduino Nano
Darauf läuft folgender Skatch:
#include "FastLED.h"
FASTLED_USING_NAMESPACE
#if FASTLED_VERSION < 3001000
#error "Requires FastLED 3.1 or later; check github for latest code."
#endif
#define DATA_PIN1    3
#define DATA_PIN2   4
#define DATA_PIN3    5
#define DATA_PIN4   6
//#define CLK_PIN   1
#define LED_TYPE    WS2812B
#define COLOR_ORDER GRB
#define NUM_LEDS    120
CRGB leds[NUM_LEDS];
#define BRIGHTNESS          255
#define FRAMES_PER_SECOND  80
  delay(3000); // 3 second delay for recovery
  // tell FastLED about the LED strip configuration
  FastLED.addLeds<LED_TYPE,DATA_PIN1,COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
FastLED.addLeds<LED_TYPE,DATA_PIN2,COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
FastLED.addLeds<LED_TYPE,DATA_PIN3,COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
FastLED.addLeds<LED_TYPE,DATA_PIN4,COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
  //FastLED.addLeds<LED_TYPE,DATA_PIN,CLK_PIN,COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
  // set master brightness control
  FastLED.setBrightness(BRIGHTNESS);
// List of patterns to cycle through.  Each is defined as a separate function below.
typedef void (*SimplePatternList[])();
//SimplePatternList gPatterns = { rainbow, rainbowWithGlitter, confetti, sinelon, juggle, bpm };
SimplePatternList gPatterns = {bpm_lava, bpm_forest, bpm_lava, bpm_ocean, };
uint8_t gCurrentPatternNumber = 0; // Index number of which pattern is current
uint8_t gHue = 0; // rotating "base color" used by many of the patterns
  // Call the current pattern function once, updating the 'leds' array
  gPatterns[gCurrentPatternNumber]();
  // send the 'leds' array out to the actual LED strip
  FastLED.show();
  // insert a delay to keep the framerate modest
  FastLED.delay(1000/FRAMES_PER_SECOND);
  // do some periodic updates
  EVERY_N_MILLISECONDS( 20 ) { gHue++; } // slowly cycle the "base color" through the rainbow
  EVERY_N_SECONDS( 1000 ) { nextPattern(); } // change patterns periodically
#define ARRAY_SIZE(A) (sizeof(A) / sizeof((A)[0]))
void nextPattern()
  // add one to the current pattern number, and wrap around at the end
  gCurrentPatternNumber = (gCurrentPatternNumber + 1) % ARRAY_SIZE( gPatterns);
void bpm_forest()
  // colored stripes pulsing at a defined Beats-Per-Minute (BPM)
  uint8_t BeatsPerMinute = 25;
  CRGBPalette16 palette = ForestColors_p;
  uint8_t beat = beatsin8( BeatsPerMinute, 32, 192);
  for( int i = 0; i < NUM_LEDS; i++) { //9948
    leds[i] = ColorFromPalette(palette, gHue+(i*6), beat-gHue+(i*8));// x2
void bpm_lava()
  CRGBPalette16 palette = LavaColors_p;
    leds[i] = ColorFromPalette(palette, gHue+(i*8), beat-gHue+(i*5));// x2
void bpm_ocean()
  CRGBPalette16 palette = OceanColors_p;
  uint8_t beat = beatsin8( BeatsPerMinute, 32, 224);
    leds[i] = ColorFromPalette(palette, gHue+(i*9), beat-gHue+(i*4));// x2
Meine Frage kann ich die pattern auch mit DMX aufrufen?
Ich muss dazu sagen das ich keine Ahnung vom programieren habe
