I am NOT a programmer in C++ and minimally understand what a program is doing, I need help with the programming.
I am using multiple Arduino Pro Minis that use Geoff Bunzas Accessory Decoder sketch (modifed) to control 8 turnout servos and 8 position indicator LED’s. This is working on my DCC system using switch commands. I would like to incorporate push button switches to throw turnouts manually without breaking DCC control. Feedback to the system is not required (yet).
I have posted a modified version of the sketch using 5 servos and 5 LEDs outputs.
Where and what would I place in the program to get switch press data (pin 5) into the mix to do the same thing as the SW001 {closed or thrown) command?
All comments appreciated.
AccDec_5Servos5SlavedOutputPins5ButtonInputPins.zip (3.38 KB)
