Hi world.
Purpose
I've recently had a problem using a level shifter to drive 5V device using 3.3V Arduino nano iot 33 (nano33).
I'm writing this to share my mistakes and hopefully get some advice on the proper usage of the level shifter.
Story
The main goal of my circuit is to send low-speed (less than 1Hz) digital HIGH/LOW signal from 3.3V nano33 device to multiple devices which receives 5V logic signal. The problem is, I do not know how much receiver devices will draw current from my circuit. Without thinking about that at the time, I built a circuit looks like this.
Pin 2 ~5 is directly connected to the nano33's digital IO and receiver devices' digital input port is directly connected to the Pin10 ~13. I should mention that nano33 and all the receiver devices share the same GND.
The datasheet of the part is attached to below.
txs0104e.pdf (1.3 MB)
The first problem that I've encountered from this project is cause by my ignorance on the maximum current output from the nano33's digital output port. I've never thought that the maximum current (7~8mA) that the digital port can output is a way smaller than the optocoupler's input current (20mA). I solve this problem using a small NPN transistor to drive 20mA LED.
Main Problem
**The next problem was related to the level shifter. 5V devices connected to the circuit above could not receive digital HIGH signal from the level shifter. **After encountering my first problem, I was able to quickly find that this is the current problem.
When I tested with a 500Ohm resistor, voltage applied to the resistor was 1.776V and the current was 3mA.
Backgrounds
As several senior members in this thread([Current and Voltage Level Shifters]) mentioned about the improper usage of the level shifter, I understood that at least I should not use the level shifter where sending digital HIGH requires more than 3mA.
Questions
Followings are my questions.
I've found the information about the nano33's maximum current output is 7~8mA in the datasheet. But I could not find a similar info from the datasheet of the level shifter I used. Is there somekind of consensus about the level shifter's current output? For example "only use level shifter were current draw is much less than 1mA" One of the mention in the thread says " this one is only for interfacing bidirectional I2C lines."( Paul_B) I want to know whether level shifters are only for very specific usages.
I would have never used the level shifter if I was trying to power an LED. I chose this because the receiver device just handles the logic inputs. In this case, where you have no idea how much current the receiver device will draw, but you know that it uses 5V, what is the best way to send 5V digital signal from 3.3V nano33?
Any advices or idea is always welcome.
