Hello everyone!
I am having a weird issue where I keep on getting a “ten” into one of my arrays (array of two lol).
Despite the previous similar code working flawlessly. (Or at least I assume it is because it works as expected).
I simply want to input through the Serial Monitor a 13 bit address in hex. However, the “higher” 5 bits are giving me an issue.
Here is my code with a comment showing where I think the problem is
(lines 42-64 and 203-223)
Also I am using an Arduino Nano from Flavin but the one I am using, contrary to a lot of the comments
on Amazon, does not need the Old Bootloader.
Thanks for any help! Even if it means a far simpler way (or simply more effective) of implementing my goal.
#include<String.h>
#include<Hardwareserial.h>
#define R_CLK 2
#define SR_CLK 3
#define W_CLK 4
#define D_CLK 5
#define SER_OUT 6
#define SER_IN 7
#define LOAD_LOW 8
const byte DEFAULT_DATA = 0xff;
const byte WRITE = 0x00;
const byte READ = 0x80;
byte mode_bit;
byte so_data;
byte addr_hi;
byte addr_low;
byte data_out[3];
byte data_in;
const String MODE_READ = "read";
const String MODE_WRITE = "write";
String user_mode;
//Setup user input data: address and write input
byte setup_user_input_data(byte addr_low_buff[], byte addr_hi_buff[]) {
bool low_error = true;
bool hi_error = true;
byte error_code = 0x00;
//Verify user input is valid
for (int i = 0; i < 2; i++) {
if (addr_low_buff[i] > 96 and addr_low_buff[i] < 103) {
low_error = false;
else if (low_error) {
if (addr_low_buff[i] > 47 and addr_low_buff[i] < 58) {
low_error = false;
//Problem with code ere as well (52-64)
if (addr_hi_buff[0] > 96 and addr_hi_buff[0] < 103) {
hi_error = false;
if (addr_hi_buff[0] > 47 and addr_hi_buff[0] < 58) {
hi_error = false;
if (addr_hi_buff[1] > 47 and addr_hi_buff[1] < 50) {
hi_error = false;
error_code = (hi_error * 2) + low_error;
if (error_code) {
return error_code;
//Interpret user data
addr_low_buff[i] -= 87;
else if (addr_low_buff[i] > 47 and addr_low_buff[i] < 58) {
addr_low_buff[i] -= 48;
addr_hi_buff[0] -= 87;
else if (addr_hi_buff[0] > 47 and addr_hi_buff[0] < 58) {
addr_hi_buff[0] -= 48;
addr_hi_buff[1] -= 48;
addr_low = (addr_low_buff[1] << 4) + addr_low_buff[0];
addr_hi = (addr_hi_buff[1] << 4) + addr_hi_buff[0];
return error_code;
//Setup data_out function
//May need to need change "bit mask" based on zero for EEPROM, that is, an erased EEPROM is 0xff.
void data_out_setup() {
switch (mode_bit) {
case WRITE:
addr_hi = addr_hi and mode_bit;
data_out[0] = 0x00 or addr_low;
data_out[1] = 0x00 or addr_hi;
data_out[2] = 0x00 or so_data;
case READ:
data_out[2] = 0x00 or DEFAULT_DATA;
//Read function
void read_EEPROM() {
mode_bit = READ;
data_out_setup();
shiftOut(SER_OUT, SR_CLK, MSBFIRST, data_out[2]);
shiftOut(SER_OUT, SR_CLK, MSBFIRST, data_out[1]);
shiftOut(SER_OUT, SR_CLK, MSBFIRST, data_out[0]);
digitalWrite(R_CLK, HIGH);
delay(50);
digitalWrite(R_CLK, LOW);
digitalWrite(LOAD_LOW, LOW);
delay(50);
digitalWrite(LOAD_LOW, HIGH);
data_in = shiftIn(SER_IN, D_CLK, MSBFIRST);
//Write function
void write_EEPROM() {
mode_bit = WRITE;
data_out_setup();
delay(50);
delay(50);
pinMode(R_CLK, OUTPUT);
pinMode(SR_CLK, OUTPUT);
pinMode(W_CLK, OUTPUT);
pinMode(SER_OUT, OUTPUT);
pinMode(SER_IN, INPUT);
pinMode(LOAD_LOW, OUTPUT);
digitalWrite(SR_CLK, LOW);
digitalWrite(W_CLK, LOW);
digitalWrite(SER_OUT, LOW);
byte addr_low_buff[2] = {0x00, 0x00};
byte addr_hi_buff[2] = {0x00, 0x00};
byte so_data_buff[2] = {0x00, 0x00};
byte error_code;
Serial.print("Enter mode read or write: ");
while (Serial.available() == 0) {}
user_mode = Serial.readString();
Serial.print('\n');
Serial.print("Lower eight bits of address in hex: ");
addr_low_buff[1] = Serial.read();
addr_low_buff[0] = Serial.read();
//Problem with code here (203-223)
Serial.print('\n');
Serial.print("Higher five bits of address in hex: ");
while ((Serial.available() == 0)) {}
addr_hi_buff[1] = Serial.read();
addr_hi_buff[0] = Serial.read();
//Debugging code right here
Serial.print('\n');
Serial.print("addr_low_buff: ");
Serial.print(addr_low_buff[1]);
Serial.print('_');
Serial.print(addr_low_buff[0]);
Serial.print('\n');
Serial.print("addr_hi_buff: ");
Serial.print(addr_hi_buff[1]);
Serial.print('_');
Serial.print(addr_hi_buff[0]);
error_code = setup_user_input_data(addr_low_buff, addr_hi_buff);
switch (error_code) {
case 0:
case 1: Serial.print('\n');
Serial.print("User input invalid on lower address input. Program ending.");
do {} while (true);
case 2: Serial.print('\n');
Serial.print("User input invalid on higer address input. Program ending.");
do {} while (true);
case 3: Serial.print('\n');
Serial.print("User input invalid on both address inputs. Program ending.");
do {} while (true);
if (user_mode == MODE_WRITE) {
Serial.print('\n');
Serial.print("Enter data to write to EEPROM in hex: ");
while (Serial.available() == 0); {}
so_data_buff[1] = Serial.read();
so_data_buff[0] = Serial.read();
so_data = ((so_data_buff[1] - 87) << 4) + (so_data_buff[0] - 48);
Serial.print('\n');
Serial.print('\n');
write_EEPROM();
else if (user_mode == MODE_READ) {
read_EEPROM();
Serial.print('\n');
Serial.print("Data read in hex form: 0x");
Serial.print(data_in, HEX);
Serial.print('\n');
Serial.print('\n');
