on-off is standard solenoid drive - MOSFET and free-wheel diode.
Proportional control requires 1/2 H-bridge (2 MOSFETs) driven from PWM signal
A high-low MOSFET driver and two n-channel MOSFETs would be one way, if the
supply is 12V it would be a good match.
Alternatively PWM via one MOSFET and one free-wheel load (a high power zener back-to-
back with a rectifier diode) could be used.
The normal freewheel diode only has a small voltage across it meaning that solenoid
current will decay much more slowly than with the other methods, limiting response
speed and giving very non-linear response to PWM duty-cycle.
The controller they recommend does a lot of things to drive your valve, including linearising the flow response and one of the most important things, control current. You are working with an inductor, AC current, not just an on=off switch pulling an inductor, impedance is now in play.
Hi, if you can get the PWM down to 22Hz, it should be fine, any higher and you will have control problems when it comes to getting the valve to open smoothly.
The impedance of the coil will limit the current flowing through it, hence how much magnetic energy is being exerted on the valve spindle.
Hi, in my experience, always use the controller and proportional valve pair that the manufacturer makes and recommends.
The controllers are easy to drive and it takes care of a lot of parameters that need to be set and adjusted to get full and efficient valve control.
