Propotional valve for hydraulics
Hello boys and gals!
Im just trying to understand the fundamentals of a valve that i’m trying to control using Arduino. I’ve attached the datasheet for the valve. It’s for a hydraulic system.
So the valve has 3 connections. Two (Coil 1 & Coil 2) for direction and one for proportional movement. For the proportional movement it needs 2 pins with voltage regulation of 0-10V.
So have i understood the following correctly?
Example 1:
Piston A
Coil 1 - Pin 4
Coil 2 - Pin 5
If both pins are low for piston A it doesn’t move. If i put for example pin 4 to HIGH, piston A retracts. Ie Pin 4 LOW and pin 5 HIGH results in piston A extending.
Is it correct that the coils can handle about 9,2-10v?
I calculated the following from the datasheet
Power consumption 25VA / maximum magnetic power 2,7A = 9,2V
i’ve been looking to buy a plc:
Whats nice about that controller is that it has 2 analog outputs 0-10v, will it be sufficient to drive the proportional coil?
As it is 24v on the digital pins i have to use some kind of voltage stepdown after the digital output for the coils that aren’t proportional (Coil 1 & Coil 2). Will this work or am i barking up the wrong tree?
All the best!
Please provide a device manufacturer and complete part number for the valve so that we may view the entire datasheet.
Mecman (Bosch Rexroth) 0811404100
I found this datasheet but i seems that the specs doesn't really match. The valves I have are really old btw!
https://www.kanflu.com/assets/Uploads/SERVO-VALVE-4WRP-..E....W-WITH-POSITIVE-OVERLAP-AND-FEEDBACK-RE29022.pdf
EDIT:
Sorry for the sloppy questions but I'm learning as i go!
The setup right now is: 1 piston 1 valve (Mecman (Bosch Rexroth) 0811404100) 1 proportional amplifer (Bosch 0811405010, Bosch Proportional Amplifier Board Drv NG6) 1 1-axis pot joystick
The goal is to make it move automatic without any user input. Maybe the simplest way is to remove the joystick and replace it with a microcontroller?
